Thermostat Design
11 replies to this topic
#1 Conrion
Conrion
  • 64 posts
Posted 13 July 2016 - 07:09 PM
So I bought almost every thermostat on rock auto... and none seem to work very well. Some don't even fit!
I can share details when I get home, but my real question is about the basic design. Is there a thermostat out there that will block the bypass port to improve cooling?
Most thermostat systems (I thought) circulate through the bypass when cold, and as it warms up the Tstat not only opens to allow flow to radiator, but also lowers a blockoff plate to the bypass port to force flow into radiator. One of the many Tstats I bought even had a bypass plate... but it didn't fit.
I ran without a thermostat previously and the car did OK... had leaky rad and many issues. Now new rad and good pressure and I'm not happy. 160 deg high flow left me boiling after "cool down" and shut off. 180 deg high flow is working better, but runs too high for my liking (top 2/3 of hash marks) so i'll be pulling it before running again.
I'm pretty confident that a tstat that blocks bypass would fix this entirely. Anyone have any insight here?
Edited by Conrion, 13 July 2016 - 07:11 PM.
#2 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 13 July 2016 - 07:21 PM
Have you tried a new water pump?
#3 M Code
M Code
  • 352 posts
Posted 13 July 2016 - 09:03 PM
Are U aware the thermostadt must be clocked into a certain position, or it can restrict the coolant flow...
Just my $0.02...  ;)
#4 TexasQuest
  • 8,673 posts
Posted 13 July 2016 - 09:06 PM
^This. You may also have air pockets in it.
88 Fiji Blue -Tsi
#5 vbrad511
vbrad511
  • 8,314 posts
Posted 13 July 2016 - 09:07 PM
Is your "new" radiator new, or just a different 30 year old radiator? Are ALL of your fans working correctly? Have you had the water pump off and seen the impeller on it? In all reality, with a decently working system a 180 stat should be cool enough to cool the motor. Some say a 160 won't keep coolant in the motor long enough to absorb the heat before it gets transfered out.
#6 ucw458
ucw458
  • 11,416 posts
Posted 13 July 2016 - 09:42 PM
Dash gauge doesn't read temp accurately.  3/4 on your gauge could be any temp.  Unless you measure the temp you wont know.
195 stat is OEM and works fine.  Having the engine too cold promotes engine wear and running rich all the time because the ECU thinks the engine isn't warmed up.  Your problem sounds like a clogged radiator, bad water pump or a bad fan.
My 87
#7 Conrion
Conrion
  • 64 posts
Posted 13 July 2016 - 11:33 PM
Fans work and rad is brand new. Could be the pump or gauge, but they did not change from before... and it boiled on shutdown, so I agree with the gauge that it was hot... I realize it may not be accurate, but it tells me enough.
I have the stat oriented so the flanges are not in the way. Don't know what "proper" alignment is. I'll take pics.
I've heard the thing about coolant not staying long enough, etc... just not true. More flow = more cool. Cools fine w/ no stat.
I guess i'll run with no stat again to be sure that the system works otherwise.
No comments on bypass?
#8 ucw458
ucw458
  • 11,416 posts
Posted 14 July 2016 - 04:40 AM
Do a compression test.
My 87
#9 importwarrior
  • 18,071 posts
Posted 14 July 2016 - 05:01 AM
go to :
www.starquestgarage.com
service manuals
i chose 1988
Cooling section 7
page 7-12
http://www.starquest...7_-_cooling.pdf
#10 TexasQuest
  • 8,673 posts
Posted 14 July 2016 - 07:57 PM
Not a good idea to run without a t-stat in a car with a coolant temp sensor for a prolonged period of time. That's just putting a band aid over a problem.
88 Fiji Blue -Tsi
#11 Conrion
Conrion
  • 64 posts
Posted 15 July 2016 - 02:47 PM
I have the part number for the factor stat. Real question here.... Is it any different?
Good point, Texas. Thanks.
#12 TexasQuest
  • 8,673 posts
Posted 15 July 2016 - 10:02 PM
Shouldn't be much different than an aftermarket t-stat. I've been running a 180 t-stat in my car for years fine with no problem. Make sure you get one with the bleeder tab thing on it, and that it's installed correctly like mentioned above.
88 Fiji Blue -Tsi
