Random parts for sale - NEW/USED/OEM/AFTERMARKET/PERFORMANCE
SFBMX88
***All prices, unless otherwise noted, include PayPal fees and ground shipping to the lower 48 states ONLY. PayPal ONLY.***
Parts added often, check back for updates! :)
*Read through this list of parts or press control+F to open a word search!
Pics below price list.
10/15/14 additions - Click here for pictures at post #29
$30 PAIR - used/no bulbs or harness included/no oil lines or fittings either/no mounting bracket with oil gauge - Equus MECHANICAL water temp and oil pressure gauges - Oil gauge uses 1/8" NPT fitting - gauges are LARGE, 2" diameter.
$30 - used/tested Throttle Position Sensor(TPS) - wire insulation breaking/cracking at junction to sensor - still works, but would be a good idea to seal this up
5/8/2014 additions - Click here for pictures at post #23
SOLD $45 - used but excellent condition* A/C delete duct(MB123891 - discontinued) with firewall plug for those looking to completely remove their air conditioning. Takes the place of the evaporator under the dash, behind glove box. ***1 available
3/9/2014 additions - Click here for pictures at post #22
$90 - 5 speed shifter modified by Mr. Andaya himself with his rebuild parts - fulcrum bushing(takes the slop out of the stock shifter)/removable shifter shaft(http://www.starquest...showtopic=93050). Includes 1 MD703619 small bellows/dust cover for shift lever and 1 MD701723 small shifter gasket(3 hole). Shifter was never used/installed after the modification was done.
SOLD $5 - MD701723 small shifter gasket(3 hole) ****$5 for the 2 available
SOLD $30 - stock 5 speed shift lever assembly - threads were cut off, was going to be rebuilt with Mr. Andaya parts, but never got around to it...
SOLD $5 - MD703619 small bellows/dust cover for shift lever
SOLD $40 - ARP head studs ****USED, UNKNOWN MILES, PULLED OFF A PARTS CAR - threads on top of one stud are slightly damaged, but still looks functional, could be cleaned up - 10 studs, 10 nuts, 10 washers included
12/31/2013 - additions - Click here for pictures at post #16
$50 - 12A intercooled compressor housing - in good shape, housing only
$20 - 12a single port wastegate actuator only
$40 - 1st gen dsm bypass valve - unmodified/uncrushed, no mating flange or gasket included
SOLD $60 - steering gearbox pulled from an 87 widebody parts car, includes pitman arm - didnt seem to leak the fews times I ran the car to move it, no guarantees!
SOLD $40 - inner left(ES2197R) AND inner right(ES2428R/MB166981) tie rod ends - brand new in box MOOG units(made in Japan) - removed from plastic to be greased - *missing one nut - MUST BUY BOTH
11/21/2013 additions - Click here for pictures at post #13
$30(set) - MD614110 injector seals only set + intake manifold gasket + throttle body base gasket + thermostat gasket
$8(set) - jet valve seals(12) + valve seals(8) + fuel pump block off plate gaskets(5) + timing cover gasket pair(2 pairs) + some random assorted gaskets that came with the original kit that may or may not fit the Starion(saw a carburetor and random water pump gaskets in there)
$20 - 201-1158 fan temp switch(beck arnley) - can anybody verify if this is the high or low temp fan switch???
SOLD $18 - MD972903 thermostat with housing gasket(1 available)
SOLD $17 - MD008839 flywheel bolts(6)
SOLD $10(set) - MF520015 o-ring sandwich plate to block small + MF520588 o-ring sandwich plate to block big
SOLD $25 - MB504732 fuel filter
SOLD $20 - mookeeh/101propose silicone pcv valve hose(black) v/c to intake manifold
SOLD $7 - 2504A012 manual transmission output shaft/tail housing seal
SOLD cam bore plug(back of head) + crescent plug(front of head)
SOLD $20(set) - MF450405 intake manifold washers(M8)(10) + MS401428 intake manifold studs(M8)(10) + MF430005 intake manifold nuts(M8)(10)
SOLD $40(set) - MD041192 exhaust manifold washers(8) + MD031537 exhaust manifold studs(8) + MD092806 exhaust manifold nuts(8) + exhaust manifold gasket + turbo to manifold gasket + turbo to down pipe gasket
SOLD $30(set) - MD611845 distributor inner shaft seal(4) + MD619987 distributor housing o-ring(4) - price is for all 8 seals
11/13/2013 additions - Click here for pictures at post #10:
RECYCLED $60 - stock intake manifold from an 88 - includes thermostat housing/used themostat/throttle plate housing/fuel rail but no mixer housing(see pics below what you see is what you get ***NO VACUUM SWITCHING THERMO VALVE INCLUDED-removed and sold)
SOLD $200 - log style, stress relieved exhaust manifold with about 9mm thick T3 flange and external wastegate - used, no cracks or leaks, wastegate is ebay unit(HKS standard 40mm knock off) with a 10 psi HKS spring installed with custom dump tube - manifold needs some studs installed for the turbo flange - this will be sold as a complete set(manifold/wastegate/dump tube) only, no gaskets included
11/11/2013 additions - Click here for pictures at post #9
$45 - 1986 alternator - NO PULLEY INCLUDED
$30 - K&N e-2873 replacement air filter - deformed from being in storage, but should still work well after cleaning/oiling
$55 - ported stock exhaust manifold - CRACKED at one runner, was welded by previous owner, but cracked again - see pics
SOLD $70 - 2.5" downpipe to match stock style Mitsubishi turbine housings - bought off another member years ago, but no longer needed
SOLD Perma-cool oil filter adapter(mounts where oil filter screws on, one piece to help relocate you oil filter)
$20 - 88/89 maf(honeycomb not in the greatest shape!)
SOLD 3 1st gen MAF PLUGS(use these to adapt your 88/89 maf plug to the 1st gen maf connector)
$20 - 86 knock box
SOLD $35 - GM 3 bar map(was used in a MegaSquirt setup)
SOLD $60 - 88/89 ecu
SOLD $35 - 88/89 knock box(upper mounting tabs were bent flat to mount in my flatty, could be bent back)
SOLD $20 - 86 boost sensor(mounted on firewall near brake booster)
SOLD $5/each - 2 stock injector resistor packs
SOLD $35 - ignition tumbler, hatch lock, and key(no door/glove box lock/fuel door/tumbler clamp)
http://i.imgur.com/BKdIJL8.jpg
http://i.imgur.com/XddUXVV.jpg
http://i.imgur.com/g0Vx67d.jpg
http://i.imgur.com/5BS0Z.jpg
Edited by SFBMX88
11/11/2013 additions - Click here for full parts list on first post:
$55 - ported stock exhaust manifold - CRACKED at one runner, was welded by previous owner, but cracked again - see pics in first post
http://i.imgur.com/LusK3oG.jpg
http://i.imgur.com/pOlah5i.jpg
http://i.imgur.com/U7a8yIU.jpg
http://i.imgur.com/wr848mY.jpg
http://i.imgur.com/gBTUS3e.jpg
http://i.imgur.com/JEaJFsY.jpg
Edited by SFBMX88
11/13/2013 additions - Click here for full parts list on first post:
Edited by SFBMX88
11/21/2013 additions - Click here for full parts list on first post
http://i.imgur.com/hWBRLTq.jpg
http://i.imgur.com/OJVZtH4.jpg
http://i.imgur.com/6Nt3WB3.jpg?1
http://i.imgur.com/xIQZu1k.jpg?1
http://i.imgur.com/niPYIu8.jpg
http://i.imgur.com/5EbOFQR.jpg
Edited by SFBMX88
  • 1 month later...
12/31/2013 - additions - CLICK HERE FOR FULL PARTS LIST ON FIRST POST
http://i.imgur.com/cvIapnj.jpg
http://i.imgur.com/gD9an8c.jpg
http://i.imgur.com/k4q6n66.jpg
http://i.imgur.com/L91bX1u.jpg
Edited by SFBMX88
  • 1 month later...
  • 4 weeks later...
3/9/2014 additions - Click here for full parts list on first post
http://i.imgur.com/SC2XNkh.jpg
http://i.imgur.com/PfENI1k.jpg
http://i.imgur.com/7qrPTD4.jpg
http://i.imgur.com/aRJRptV.jpg
Edited by SFBMX88
  • 1 month later...
5/8/2014 additions - Click here for full parts list on first post
Edited by SFBMX88
I'll take these if still available (1) MD972903-thermostat+gasket (2) MD70123 -small 3 hole shifter gasket x2.
What other gaskets are available? I also want the flywheel bolts MD00839,also do you have another exhaust manifold gasket?
Edited by randy
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
