Fanta Posted March 24, 2008 Report Share Posted March 24, 2008 http://img.photobucket.com/albums/v365/starquest32/car%20stuff/87interiorfeb07.jpg AJ forgive me for using your car as an example lol But who here is missing that little insert piece in the lower dash portion near the key ignition? I know both of my cars have had it NOT there. Poll is at the top, vote Link to comment Share on other sites More sharing options...
Maxzillian Posted March 24, 2008 Report Share Posted March 24, 2008 Technically I still have it, but after I broke it while removing it to install a switch, it requires the switch to keep it in place. Since I am no longer using aforementioned switch, it's no longer in the car. Link to comment Share on other sites More sharing options...
Zack_Morris Posted March 24, 2008 Report Share Posted March 24, 2008 i broke the little clips that hold it in place while installing my turbo timer....sucks Link to comment Share on other sites More sharing options...
BOOSTED88tsi Posted March 24, 2008 Report Share Posted March 24, 2008 both my cars had it Link to comment Share on other sites More sharing options...
racer_amx Posted March 24, 2008 Report Share Posted March 24, 2008 Technically I still have it, but after I broke it while removing it to install a switch, it requires the switch to keep it in place. Since I am no longer using aforementioned switch, it's no longer in the car. For those who have broken clips or any other plastic pieces in their cars; Do not throw the clips away, get some super glue and and some baking soda. First you wanna scuff up around the area you wanna bind back together with some sandpaper to give the glue more bite, then you apply some superglue, lastly sprinkle a lot of baking soda over the glue and press it together Quickly (note: you might wanna have someone else sprinkle the soda while you hold the pieces very close together as the soda makes the glue harden rock solid within seconds). The plastic weld will be extremely strong. I have used this method to save busted consoles ect..., you can even sand it down and paint the part with interior paint and no one will ever be able to tell. Link to comment Share on other sites More sharing options...
shift1313 Posted March 24, 2008 Report Share Posted March 24, 2008 i dont even think the hole is there on my 84. id have to have a look Link to comment Share on other sites More sharing options...
importwarrior Posted March 24, 2008 Report Share Posted March 24, 2008 mine fell out after i broke the tabs but a little rubber cement glue and a little tape to hold it till it dried. back in place. Link to comment Share on other sites More sharing options...
Tman Posted March 24, 2008 Report Share Posted March 24, 2008 mine broke when taking dash apart for white guage overlays soo a little superclue fixed it right up Link to comment Share on other sites More sharing options...
Tuskan Posted March 24, 2008 Report Share Posted March 24, 2008 still have mine, but i modded a toggle switch in there, and works perfectly Link to comment Share on other sites More sharing options...
Dad Posted March 24, 2008 Report Share Posted March 24, 2008 Mines gone Dad Link to comment Share on other sites More sharing options...
UNDRPRSR Posted March 24, 2008 Report Share Posted March 24, 2008 I still have the piece but it's not on the car, along w/ the rest of that panel. That whole piece weighs around 10 lbs and if you remove it, you can have more knee room and a lighter car. There is another panel under that so with an easy sheet metal fuse cover and hood release relocation, you might have an hour worth of work in it to save 10 lbs. The second picture is how you save an additional eight pounds by removing the glove box panel. Your glove box now weighs three pounds instead of 11! Link to comment Share on other sites More sharing options...
Mazarin Posted March 24, 2008 Report Share Posted March 24, 2008 I have mine. It's broken and in the glovebox w/ the broken steering adjuster handle Link to comment Share on other sites More sharing options...
Edde Posted March 24, 2008 Report Share Posted March 24, 2008 For those who have broken clips or any other plastic pieces in their cars; Do not throw the clips away, get some super glue and and some baking soda. First you wanna scuff up around the area you wanna bind back together with some sandpaper to give the glue more bite, then you apply some superglue, lastly sprinkle a lot of baking soda over the glue and press it together Quickly (note: you might wanna have someone else sprinkle the soda while you hold the pieces very close together as the soda makes the glue harden rock solid within seconds). The plastic weld will be extremely strong. I have used this method to save busted consoles ect..., you can even sand it down and paint the part with interior paint and no one will ever be able to tell. Mines busted. If this makes super/crazy glue work on plastic then you are the man. Link to comment Share on other sites More sharing options...
Shaggy_TSi Posted March 24, 2008 Report Share Posted March 24, 2008 I had to remove that piece to work on the steering column, broke it , but then i applied crazy glue to the broken piece and waited for it to dry, worked like a charm, i even had to apply force when i installed it and it didnt break. :woot: Link to comment Share on other sites More sharing options...
Hoosierquest Posted March 24, 2008 Report Share Posted March 24, 2008 Mine is gone. It took me eight years to find out the dash clock is illuminated. mine never worked and I assumed none were lighted, untill i rode in someone elses. Link to comment Share on other sites More sharing options...
