flatty86 Posted March 5, 2013 Report Share Posted March 5, 2013 Does anyone know the torque specs for out manual transmission? Transmission is almost done. Thank you. Link to comment Share on other sites More sharing options...
scott87star Posted March 5, 2013 Report Share Posted March 5, 2013 As in tightening the bolts? As in how much it can handle? Normally the clutch is rated for its ability to hold a certain torque, hopefully the tranny is higher than that. Lots of guys have spun the teeth off the manuals though, it seems to happen above 350-400 lb-ft. Factory clutch would never hold that. As far as tightening torque, http://www.starquestgarage.com, Link to comment Share on other sites More sharing options...
shift1313 Posted March 5, 2013 Report Share Posted March 5, 2013 Does anyone know the torque specs for out manual transmission? Transmission is almost done. Thank you. Starter motor - 16-23ftlbsengine to tranny 31-40mainshaft locking nut - 196-216countershaft locking nut - 116-137idler shaft locking nut - 15-43drain plug - 44oil filler plug - 22-25Back up light switch - 22under cover - 6-7seal plug - 22-30speedo clamp - 7.5-9 is that what you need? Link to comment Share on other sites More sharing options...
flatty86 Posted March 6, 2013 Author Report Share Posted March 6, 2013 yes thank you Link to comment Share on other sites More sharing options...
