Cerakote thermal barriers
26 replies to this topic
#1 tux
tux
  • 1,239 posts
Posted 05 April 2018 - 10:58 AM
Hey all,
Wondering if any of you guys used this on turbine housings and downpipes.  If so, does anyone know how much under hood temps reduced?
I'm thinking about getting my downpipe done, then possibly the turbine housing and wondering if it's worth it for keeping things from frying
#2 speedyquest
speedyquest
  • 4,015 posts
Posted 05 April 2018 - 11:03 AM
I've got my turbo's hotside coated and I can say that its helped cut down on radiant heat but I think what it does better is help with spool.
EDIT:  A picture for you. You can see both the coated manifold and hotside.
Edited by speedyquest, 05 April 2018 - 11:05 AM.
#3 tux
tux
  • 1,239 posts
Posted 05 April 2018 - 12:44 PM
Cool thanks.  Did it help much with the heat or marginally?  I'm more concerned with heat then the spool :)
#4 speedyquest
speedyquest
  • 4,015 posts
Posted 05 April 2018 - 12:59 PM
I think if you aren't looking for every little bit of help you should instead spend money on a turbo blanket. While the coating does help its not a massive difference. Of course if you did both a coating and a blanket then you'd see a significant change in under hood temps.
#5 tux
tux
  • 1,239 posts
Posted 05 April 2018 - 08:55 PM
Looks like I'll do both!  I won't bother with the turbine housing until I get it milled or find a cheap 16g
#6 BC_99
BC_99
    Plays in traffic
  • 5,199 posts
Posted 06 April 2018 - 08:10 AM
Are you talking about the same cerakote that is used on firearms? Or do they offer a heavier, more durable coating that you are considering? Speedy, exactly what is on your mani and hotside?
BC
#7 psu_Crash
psu_Crash
  • 7,067 posts
Posted 06 April 2018 - 08:33 AM
This is the stuff you want. I've had SwainTech coat a few things for me with great results.
http://swaintech.com...haust-coatings/
My Feedback Link
#8 speedyquest
speedyquest
  • 4,015 posts
Posted 06 April 2018 - 08:59 AM
BC
I don't think the company who makes the gun coating makes the thermal coating by roughly the same name but I could be mistaken. I will say though that I know there is a thermal coating with that name. As for what brand coating is on my hotside and manifold, I'm not sure. Its whatever RonnieJ and jdlAutoDesigns have deemed good as they did both of them. Whatever it is its durable as hell, hasn't discolored, or flaked off in any way.
#9 tux
tux
  • 1,239 posts
Posted 06 April 2018 - 09:05 AM
Same company as the gun coatings, just a different product
#10 speedyquest
speedyquest
  • 4,015 posts
Posted 06 April 2018 - 09:20 AM
I stand corrected haha.
#11 Funky Phil
Funky Phil
    Super Pooper
  • 6,423 posts
Posted 06 April 2018 - 12:27 PM
And how many holes are in your hood? Haha
Edited by Funky Phil, 06 April 2018 - 12:28 PM.
#12 speedyquest
speedyquest
  • 4,015 posts
Posted 07 April 2018 - 03:44 PM
Fair point but I also believe it's pretty common knowledge that ceramic coating does less for cutting down radiant heat than a blanket does. That was my main point 😎
#13 psu_Crash
psu_Crash
  • 7,067 posts
Posted 07 April 2018 - 07:43 PM
The blankets do a very good job to regulate underhood heat. But the ceramics keep heat in the header. Scavenging effect so they say. Keep the heat where it's supposed to be I'd always a good call. Boost up boys!
My Feedback Link
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,423 posts
Posted 08 April 2018 - 08:49 AM
I know, just messing with ya.
On a serious note, why do you think it helped with spool on your setup?
#15 speedyquest
speedyquest
  • 4,015 posts
Posted 08 April 2018 - 10:28 AM
Oh I know man haha, no worries at all. I clarified for others. Well the basic science behind it says that the coating helps keep the heat in the manifold and therefore helps increase the exhaust gas velocity. That velocity helps spool the turbo. But keep in mind I'm not saying you ceramic coat a big turbo that normally spools at 5k and now it magically spools at 2k. Instead it's more like a couple hundred rpms faster. No it's not massive increase but couple that with other things like a nice electronic boost controller and you've got something.
#16 Funky Phil
Funky Phil
    Super Pooper
  • 6,423 posts
Posted 09 April 2018 - 01:19 PM
I know how it os supposed to work. I meant first hand experience with before and after testing. Especially with a tighter hotside on yours
#17 speedyquest
speedyquest
  • 4,015 posts
Posted 09 April 2018 - 03:35 PM
Ah ok gotcha, sorry. I wasn't trying to dumb it down for you, I know your a knowledgeable guy. I just thought we were talking in generalities not specifics. My turbo is a small 16g with a TD05H hotside and I noticed boost starting to come on 500 rpms faster with the manifold with its coating and then after modifying the hotside to be external wastegate and coated I saw another 200 or so rpm increase in speed. So that's what I was referring to. Its not massive but you'll notice.
#18 tux
tux
  • 1,239 posts
Posted 27 April 2018 - 09:14 AM
Just an update.
Gave the baby 12a a turbo blanket from Fleabay.  Used some cheap header wrap from Amazon on the Exchaust manifold, and had my downpipe cerakoted.
Underhood is pretty cool.  I can put my hand on the turbo without my skin melting off, however it is not comfortable.
Underhood temps are good.  Next up is some heat reflective tape on the OCVP until I can find a cheap tubing bender.
#19 importwarrior
  • 18,181 posts
Posted 27 April 2018 - 11:14 AM
I used header wrap on my OVCP.
#20 tux
tux
  • 1,239 posts
Posted 27 April 2018 - 01:31 PM
Oh that might be a good idea too.  But I'll test out the heat reflective tape since I already bought it :)
