redTSI99 Posted November 12, 2007 Report Share Posted November 12, 2007 Alight guys just purchased a 86 conquest tsi..knowing it had a knock tore the block down and found on it #4 rod bearing was spun..took it to the machine shop today and found out #4 journal was 25 thousandths down...so he suggested to find a crank in better conditon...if anyone has one let me know he has my block and pistons just need a crank to get finshed...thanks guys Quote Link to comment Share on other sites More sharing options...
shoquest2007 Posted November 13, 2007 Report Share Posted November 13, 2007 I just purchased one from O'reilly's Auto Parts, It was 177.00 with bearings. And I was able to get it the same day, they had it in the warehouse. Check that out and see if you have a parts house near by. If not I can get you one here and ship it to you. Good Luck. And yes i have already used one of these cranks and have had no problems with it. Quote Link to comment Share on other sites More sharing options...
madhatch Posted November 13, 2007 Report Share Posted November 13, 2007 if you dont get one before thanx giving, i have an extra.. some cash plus your old crank...using it for a welding project... Quote Link to comment Share on other sites More sharing options...
madhatch Posted November 13, 2007 Report Share Posted November 13, 2007 i will bring it to chatanooga..... Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 13, 2007 Author Report Share Posted November 13, 2007 thanks guy I will let you know Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 13, 2007 Author Report Share Posted November 13, 2007 I just purchased one from O'reilly's Auto Parts, It was 177.00 with bearings. And I was able to get it the same day, they had it in the warehouse. Check that out and see if you have a parts house near by. If not I can get you one here and ship it to you. Good Luck. And yes i have already used one of these cranks and have had no problems with it. are the cranks...still in standard specs...and have the nitride treating?? Quote Link to comment Share on other sites More sharing options...
HotrodTSi Posted November 13, 2007 Report Share Posted November 13, 2007 I just purchased one from O'reilly's Auto Parts, It was 177.00 with bearings. And I was able to get it the same day, they had it in the warehouse. Check that out and see if you have a parts house near by. If not I can get you one here and ship it to you. Good Luck. And yes i have already used one of these cranks and have had no problems with it. are the cranks...still in standard specs...and have the nitride treating?? It is most likely a Caravan crank. Those were not hardened and I'm not sure how one would hold up in a Turbo motor. Quote Link to comment Share on other sites More sharing options...
quikconq Posted November 13, 2007 Report Share Posted November 13, 2007 I just purchased one from O'reilly's Auto Parts, It was 177.00 with bearings. And I was able to get it the same day, they had it in the warehouse. Check that out and see if you have a parts house near by. If not I can get you one here and ship it to you. Good Luck. And yes i have already used one of these cranks and have had no problems with it. are the cranks...still in standard specs...and have the nitride treating?? It is most likely a Caravan crank. Those were not hardened and I'm not sure how one would hold up in a Turbo motor. cross refence the two part numbers,,,the part number from a caravan crank and the number for the starquest crank might be suprized Quote Link to comment Share on other sites More sharing options...
quikconq Posted November 13, 2007 Report Share Posted November 13, 2007 autozonelists the cranks as the same part number Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 13, 2007 Author Report Share Posted November 13, 2007 they do list them as the same number..any suggestions on how to really find out..or just have them order one in and check the number ?? Quote Link to comment Share on other sites More sharing options...
quikconq Posted November 13, 2007 Report Share Posted November 13, 2007 nah they will give you a caravan crank,,,,dont botherunless you want to have it nitrided glbryen Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 14, 2007 Author Report Share Posted November 14, 2007 I don't have any plans for this car being built wise..just a nice little daily driver...what would be the problem with using the caravan crank I know its not treated, but im not looking for anything more than stock...would it be ok to use for what im looking for or should I go the other direction?? Quote Link to comment Share on other sites More sharing options...
jolyrgr Posted November 14, 2007 Report Share Posted November 14, 2007 There is a reason why turbo cars get the better pistons and crank. There are also reasons why these cars have a bad reputation of breaking down. Taking the cheap way out will always cause problems in the future. Get the right parts, spend the cash, and get it right the first time. JR Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 14, 2007 Author Report Share Posted November 14, 2007 thats all i needed to hear...just need a little motivation to get going in the right direction Quote Link to comment Share on other sites More sharing options...
tim si Posted November 14, 2007 Report Share Posted November 14, 2007 ive got an entire engine i pulled out a couple months ago.118,000miles.it was running no knock or rattle when i pulled it out.you can have it for 200 if you want it.im prob the closest.i just need it out of the way.also got a couple parts cars if you need anything else Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 14, 2007 Report Share Posted November 14, 2007 thats a sweet deal^^^^^^ if not ive got one that needs to be turned, $50, but personally id jump on that motor if i were you. Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 14, 2007 Author Report Share Posted November 14, 2007 ive got an entire engine i pulled out a couple months ago.118,000miles.it was running no knock or rattle when i pulled it out.you can have it for 200 if you want it.im prob the closest.i just need it out of the way.also got a couple parts cars if you need anything else hey man can you send me your address so I can mapquest it...may be the best route to go for me let me know man Quote Link to comment Share on other sites More sharing options...
Lives4Speed Posted November 14, 2007 Report Share Posted November 14, 2007 LMK if you go that route so I do not spend $$ on turning this crank 4 U. L4S Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 14, 2007 Author Report Share Posted November 14, 2007 i will man..if this falls through I will go your route Quote Link to comment Share on other sites More sharing options...
HotrodTSi Posted November 14, 2007 Report Share Posted November 14, 2007 It looks like Eric has your back if that deal fails. He'll do you right. Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 14, 2007 Author Report Share Posted November 14, 2007 yea man I was gonna let him do it for me until this guy came about with the complete engine..hard to pass that deal up depending on condition of engine when I see it Quote Link to comment Share on other sites More sharing options...
tim si Posted November 14, 2007 Report Share Posted November 14, 2007 Well i wouldnt exactly just throw this engine in and go,but it is a running engine.it did smoke a little but i think it was the turbo.i bought the car and drove it home.its an entire engine minus injectors and turbo.ill pm the address Quote Link to comment Share on other sites More sharing options...
jwrape Posted November 14, 2007 Report Share Posted November 14, 2007 Alight guys just purchased a 86 conquest tsi..knowing it had a knock tore the block down and found on it #4 rod bearing was spun..took it to the machine shop today and found out #4 journal was 25 thousandths down...so he suggested to find a crank in better conditon...if anyone has one let me know he has my block and pistons just need a crank to get finshed...thanks guys Ewww, that's scary... Cause mine spun the 4th bearing as well. I hope my crank is ok... Quote Link to comment Share on other sites More sharing options...
redTSI99 Posted November 15, 2007 Author Report Share Posted November 15, 2007 I don't know how long the car was ran after the knock started..all other journals look great...number 4 was gone..it wasnt a pleasant visit to the machine shop Quote Link to comment Share on other sites More sharing options...
jwrape Posted November 15, 2007 Report Share Posted November 15, 2007 I don't know how long the car was ran after the knock started..all other journals look great...number 4 was gone..it wasnt a pleasant visit to the machine shop Yea, same here. 1-3 are pretty...#4 is not.... I am thinking I might be in the same boat but won't know until I take it up to the shop. Quote Link to comment Share on other sites More sharing options...
