Turbo Cary Posted October 4, 2013 Report Share Posted October 4, 2013 Hey y'all I have an fic8 I plan on piggy backing with my stock ecu to get a little more tunability. I figured I'd start a topic about this in case anyone has any input. Heres my current setup so far. 86 conquest with a rebuilt (stock) bottom, non jet head with some valve work, stock cam 89 ecu running factory l and m injectors2nd gen maf translatorAdjustable fpr 14g turbo had been sent off and upgraded to a big 16g with a td06 turbine wheel (stock housing bored to fit) running 15 psi at the moment due to lack of wideband. I got the fic from my buddy who owed me money so I figured I would put it to use. It can accept various different trigger options and has an internal map sensor from what I understand so I could theoretically remove the maf t or keep it for more accurate readings. Before install I will purchase a wideband sensor. Most likely the new boost/wideband combo that aem offers so I can remove my a pillar setup and put it into the stock boost gauge location. ---off topic, I also have questions about the maf t. I have a 3" sensor but the car runs like crap in that mode. It runs perfect in 3.5" maf mode with the current settings: Aux 0 Base 2 Idle E Mid 0 WOT 1 Any recommendations to change it? my car is an 86 but its harness was setup for the 6 pin maf and 87 ecu. I changed to an 88 after my heater core leaked coolant onto my 87 ecu and fried it. Production date on the chassis is 1/86 but is it possible to have a half year? I appreciate yall taking the time to read this and make an suggestions Link to comment Share on other sites More sharing options...
StarquestRescue Posted October 4, 2013 Report Share Posted October 4, 2013 I do not know that any one here has tried it. The fic 8 should work good if you take the time to learn it. Data logging is key to getting results. At some point you may need to up size the injectors a little. The secondary should be about 75-80 % bigger than the primary. The fic 6 will not work on these cars, but you said it is a 8 so give it a go. Link to comment Share on other sites More sharing options...
