Project Zero G Starion - Ultimate Street 4G64 Swap
15 replies to this topic
#1 DJpowerHaus
DJpowerHaus
  • 2,438 posts
  • Interests:If that has a Spoon engine, mine's got a Shovel.
Posted 27 February 2019 - 01:34 PM
1987 Conquest
VIN: JJ3CC54N5HZ002713
69,400 miles
I bought this clean low mileage car 8 years ago because I wanted to do the perfect Starion 4G6x swap.  I had done 4 other swaps and helped with dozens of others on the website I created to help everyone do RWD 4G63 swaps: www.ProjectZeroG.com .  My vision was "How Mitsubishi would have built a DOHC Starion... with a bit of polish"
This is the culmination of everything I've learned over 15 years working on Starion 4G63 swaps.  There is so much tiny details done on this it's hard to describe.  Lots of OEM parts from different makes / models / cars / trucks / international models that tie it all together.
I've been driving it to work recently and it starts and runs without fail. Made 340hp at 14psi.  Full boost by 3000rpm.
Body:
L47 Athens Olive Green paint (1973 Galant / FTO paint) (originally silver)
Maroon Interior
88 Starion tail lights
Starion badges, black grill,
Tubed front fenders for the crazy steering (See handling below)
Amazingly rust free.  Frame rails are a little crushed though.
Remote battery (trunk) with cutoff switch.
Engine:
2.4L 4G64 wideblock (1G 6 bolt)
Wiseco forged pistons
Scat forged rods
100mm forged crank (oem)
DOHC 1G head
Custom "2400 DOHC" valve cover with -10AN breathers to catch can
Brian Crower springs + titanium
Forced Performance FP3 cams (Specifically developed for 2.4L turbo)
Water modifications front and rear for better water flow in RWD application
Cometic MLS headgasket w/ extra holes punched for front water exit
ARP head studs
Custom front exit water neck welded in w/ DSM thermostat housing
Customized RWD water pump for DOHC
RWD 2.0 Starion turbo oil filter housing
RWD D50 oil pan
Custom front mounted CAS
Setrab Oil Cooler w/ -18AN steel braided lines
Turbo:
HX35 Turbo
Bullseye Performance .55 A/R turbine housing for DSM
Forced Performance Cast exhaust manifold
35mm External Wastegate
2.5" custom intercooler pipes w/ silicone couplers.
27x12x3" CX Racing Intercooler
3" *DM full exhaust w/ custom v-band downpipe
Turbo XS RFL Blow Off Valve
Boost Controller
Engine Management:
Autronic SMC full standalone ECU (autotune / 4 channel ignition / 4 channel injection / rally antilag)
M&W Pro-14 4 channel CDI w/ T1 racing harness + CBR coils
1000cc FIC injectors
Walboro GSL392 w/ -8AN lines 1/2" aluminum hardlines
Aeromotive A1000 fuel pressure regulator
-6AN lines to and from fuel rail
HKS super oldschool Boost and EGT gauges (orange on black)
Innovate LC-1 Wideband O2
Serial -> USB adapter + Cable
Drivetrain:
RX7 Turbo II (S5) Transmission
Short Shifter
87 B2600 bellhousing (very rare)
Fidanza Starion 240mm flywheel
Competition Clutch Stage 4 - Sprung hub 6 puck
Custom Driveshaft
6 bolt rear end
Handling:
Stedebani Urethane Suspension bushings
6 bolt Diff + axles
Trust Stut tower bar
S13 240SX HICAS (faster rate) Steering Rack on modified Starion crossmember
Starion oil cooler used as power steering cooler w/ -6 steel braided lines
S14 5 lub Hubs "Awesometron 5000" steering knuckles by MA-Motorsports
300ZX 4 piston front brakes with custom steel braided lines
Tein HA coilovers up front - *DM coilovers rear.
Long NASCAR studs up front for using a spacer to clear the front brakes
45mm spacers rear
DSM steering wheel
Wheels:
4x Polished 9" SHP
BONUS INCLUDED PARTS:
2 "Turbo" Starion rear hatch glass pieces
Black 88 Dash in decent shape
2x Brand new Nexen N5000 245/45 Z R16 tires
Spare HX35 turbo
$9000
Right now it needs a transmission.  I had put a spare in a few months back, but it had some bearing issues after a few miles so I'm having the original rebuilt.
Edited by DJpowerHaus, 10 December 2019 - 04:08 PM.
:: Project 0G ::
#2 Preludedude
Preludedude
  • 3,505 posts
Posted 27 February 2019 - 04:41 PM
This car is just....
#3 importwarrior
  • 18,369 posts
Posted 27 February 2019 - 04:44 PM
Amazing.
Wish I had 8K
#4 lyons8821
lyons8821
  • 296 posts
  • Interests:My boy, my quest and my friends.
Posted 28 February 2019 - 12:17 PM
I am loving this car.  Post some interior pictures please.
#5 twoshady
twoshady
  • 45 posts
Posted 01 March 2019 - 10:13 AM
crazy cool car.  good price for all the work that was done.
#6 TexasQuest
  • 9,126 posts
Posted 01 March 2019 - 12:48 PM
That car is truly a masterpiece. I'm very sorry you have to sell it.
88 Fiji Blue -TSi
#7 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,413 posts
Posted 01 March 2019 - 04:23 PM
someone is going to get a helluva deal on a KILLER QUEST !
          MOPAR POWERED
#8 DJpowerHaus
DJpowerHaus
  • 2,438 posts
Posted 03 March 2019 - 11:17 AM
Interior Picks Update Below!
Edited by DJpowerHaus, 04 June 2019 - 01:40 PM.
:: Project 0G ::
#9 jonboyb
jonboyb
  • 2,621 posts
  • Interests:Not saving money
Posted 04 March 2019 - 02:21 PM
That maroon dash is probably the one thing between me and a divorce :lol:   Swapped one long ago and swore I'd never do it again.  Loving the car though.
Finished up a 4G64 build for Brandon Martin (Pr4mnceman.....miss seeing him around) years ago and it was consistent 11's car with drag radials and FP Red turbo.  Said I'd own one eventually but alas never happened.
87 Valencia Quest - MPI MSII
84 Mezzon Gold Dodge Conquest - Timecapsule
16 Durango RT - Modded
19 Ecoboost F-150....Cause TT is Better than a V8
#10 speedyquest
speedyquest
  • 4,338 posts
Posted 04 March 2019 - 03:33 PM
He did say he'd swap it over lol
#11 DJpowerHaus
DJpowerHaus
  • 2,438 posts
Posted 05 March 2019 - 08:01 AM
I had it 90% out to restore the heater box internals, but because I had to drive the thing to work 6 hours later, I opted to save that dash swap for later.  Part of me just wants to put a fuzzy dash over over it, but I can't bring myself to sell a car for 5 figures with a covered up problem.
:: Project 0G ::
#12 StreetVelocity
StreetVelocity
  • 230 posts
  • Interests:turbo cars and road racing,drifting
Posted 22 March 2019 - 01:14 PM
This cars amazing, I cant believe someone hasn't bought it yet.
#13 lyons8821
lyons8821
  • 296 posts
Posted 22 March 2019 - 05:32 PM
I want it really bad. Trying to get cash up.
#14 acidbath
acidbath
    Otaku Nerd
  • 1,665 posts
  • Interests:Turbo lover. USAF Veteran.
Posted 05 April 2019 - 06:29 PM
Check your PM.
Fist of the North Starion.
88 Red TSi (SOLD)
99 Pearl White 3000GT SL(SOLD)
95 Green Eclipse GSX(SOLD)
91 3000GT VR-4 (Dud, sold)
95 3000GT VR-4 (SOLD)
03 Toyota Camry (Sold)
4x BMW 318d/320d/330d Touring Wagons (Sold)
07 C30 2.0D (Sold)
10 Honda Fit (Sold)
07 Acura RDX SH-AWD Turbo SUV daily driver.
#15 DJpowerHaus
DJpowerHaus
  • 2,438 posts
Posted 04 June 2019 - 01:56 PM
Finally got around to swapping transmissions and moving the shifter forward so it fits in with the stock center console and boot.  Also added a few layers of rubber, aluminum, and insulation and it keeps the sound from coming in through the trans tunnel.  Now it's just a mean MEAN bark from the tailpipe... and wastegate dump :-D.
It is nice to have it all back together finally.  Haven't really gotten to rip on it with the old transmission, but this one I can rev to the moon without vibration.  Old trans had a bad input bearing if the buyer wants it for a rebuild, it is included.
Here are some pics with the interior back together.
Passenger seat has one seam that is popped.  And the dash is pretty sun damaged, but I am including a spare black dash which I plan on using to make a black/maroon 2 tone look.  Get it before I do that work and save some money.
As I said in the first post, as I put things back together, the price goes up.  Price as it sits now is $10,000.
:: Project 0G ::
#16 DJpowerHaus
DJpowerHaus
  • 2,438 posts
Posted 04 June 2019 - 06:03 PM
Still available.  Stored in a garage now.
Mostly caught up on other projects that kept me swamped for a year so I can put some time into rebuilding the Turbo II transmissions.
Edited by DJpowerHaus, 09 December 2019 - 02:02 PM.
:: Project 0G ::
