MOOKEEH MK1 AJUSTABLE SUSPENSION PROJECT
101PROPOSE
hello members,
i received some sample suspension parts from a manufacturer.
i am thinking about modifying them to make some protoype suspension parts for starquests.
control rod is one and adjustable swaybar endlinks(Sully's idea) is another one.
if you have any ideas on suspension parts we need, please let me know.
thanks,
101
http://www.mookeeh.com/starquest/189.JPG
  • Replies 157
  • Created
  • Last Reply
Top Posters In This Topic
Keep up the great work, 101! The stuff you're pumping out is top notch!
Lives4Speed mentioned another concern... the steering system. We desperately need a rack-n-pinion alternative to our bs OEM steering system. Please help!
Rack N Pinion!!
I think DJpowerhaus used a 240 Rack? I wish I had the time to devote to it. The steering box is a dinosaur in comparison.
L4S
Edited by Dan
Rack N Pinion!!
L4S
i will check with the manufacturer about the rack N Pinion but most likely, they will ask for a sample prototype.
i will let you know.
thanks,
101
thanks,
101
I'd be VERY interested in a Rack-N-Pinion steering conversion as well, I'd been waiting for years :hmm3grin2orange: and I'm sure so have other people.
These will probably be more popular than any adjustable suspension pieces........but a lot more work to get to work properly..
Zack
Before you go making adjustable things, make some roll center spacers. Or what ever they are called. They are spacers that go on top of the ball joint and below the strut. They take up about one inch of space or so and they correct the suspension angles on a lowered front end. They are popular on corolla's that have very similar suspension designs to our cars.
http://www.technotoytuning.com/productdetail.php?p=672
http://www.technotoytuning.com/media/products/rca_02.jpg
However, 101, you should make them with a hole in the side so when using your adjustable coil-overs you can lower the front end more and still be able to adjust the stiffness.
Also, I think you should look at more corolla stuff instead of 240 stuff to copy. The items you have in that picture are for a completely different suspension setup.
Edited by Casey_L
haha, Casey, I came in here to post about roll center spacers (although I didn't know what they were called before coming in here)
Using them drops the suspension arm back to closer to stock angles, reducing camber (or setting it back closer to stock), and would lessen the dependence on camber plates when lowering the front.
Derek
it is real simple and easy to make those - whatever they are called.
if i get enough interest, i will make them.
check out the picture below, i am done with the cad/cam drawing already.
let me know
thanks,
101
http://www.mookeeh.com/starquest/strutspacer.jpg
hello members,
i worked on my pillow ball tention controll rod prototype. it is almost done and i will finish it up next week.
i am using a rod about 9.5" thick compare to 6.25" thick stock ones.
Sully, if you read this, can you send me again the picture of adjustable endlink you sent me through the old forum? i did not save the picture and it is gone now with the old forum.
thanks,
101
http://www.mookeeh.com/starquest/N-222.JPG
http://www.mookeeh.com/starquest/N-223.JPG
http://www.mookeeh.com/starquest/N-224.JPG
Edited by 101PROPOSE
lol... I was just looking for it earlier. No luck on my end either. All I can find are the ones with the horizontal mounts
Kind of like the lower mount here. The other pic had a more stout piece
http://www.awrracing.com/store/popup_image...cts/rrlink2.jpg&
http://www.frsport.com/images/product_images/thumbnail_Largus_SwayBarEndLinks_4.jpg
Edited by Sully
I suggest you contact ryddler direct... he's probably working with the old SQC.com content somewhere that we can't access. Maybe he can find the picture you're looking for.
what are the advantages of adjustable tension rods?
Caster adjustment. Ours are already adjustable to a certain extent. Those are just easier to adjust
Edited by Sully
Oh I see. Thanks. 101, I am interested in some roll center adjusters, however you should mill a hole in them so that I can still adjust the knob on your adjustable struts.
I'd be in for a set of the roll center spacers/adjusters. Just get us a price estimate ;)
Thank you
Derek
thanks for your interest.
they(technotoys) sell theirs for $80.00, how about $69.99 for mine? :)
i will need more than 2 orders...at least 6 sets
anyone else need them?
check out the installed on a car(not starquest) picture below. i found them on ebay.
thanks,
101
http://www.mookeeh.com/starquest/roll1.jpg
http://www.mookeeh.com/starquest/roll2.jpg
http://www.mookeeh.com/starquest/roll3.jpg
here are the advantages of adjustable tension rods i found
dramatically increase handling, corner speed, and steering response
high rigidity pillow ball rods increase stability under heavy braking and straight line acceleration by reducing toe out and friction
turn buckle allows for easy simple adjustment in wheel alignment settings/changes
thanks,
101
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
