Engine main bearing difference s
12 replies to this topic
#1 boostinmini
boostinmini
  • 805 posts
  • Interests:G54b, 4G63, anything mitsubishi especially pre 2000s, custom fabrication and mountain biking.
Posted 31 May 2017 - 09:39 AM
Hello
I am currently rebuilding a 4d56 which is very similar to a 2.6, even same part number for engine bearings
Question I have is I got a set if clevvitte main bearings and according to the manual I I should have  grooved bearings for the top and noon grooved for the bottom but they all appear to be grooved, what should I do?
Is this normal?
#2 Guest_STARION_NORTH_*
  • Guests
Posted 31 May 2017 - 09:48 AM
Fully grooved main bearings allow for a full 360-degree crank oiling. The downside to having the groove in the bottom half bearing shell is that it reduces the load carrying surface area.
#3 boostinmini
boostinmini
  • 805 posts
Posted 31 May 2017 - 09:53 AM
Is it normal for mine to be fully grooved?
#4 Guest_STARION_NORTH_*
  • Guests
Posted 31 May 2017 - 10:11 AM
http://www.enginebui...on-performance/
Hope this helps.
Edited by STARION_NORTH, 31 May 2017 - 10:16 AM.
#5 boostinmini
boostinmini
  • 805 posts
Posted 31 May 2017 - 10:31 AM
Ok interesting read, so I thought clevitte bearings where the go to standard?
Maybe these are very old stock?
Since this is a diesel, fully grooved seems like a bad idea
#6 Guest_STARION_NORTH_*
  • Guests
Posted 31 May 2017 - 11:05 AM
I would guess that they are either old stock or just simply a standard replacement for the original design? Are the original bearings from the motor fully grooved? I don't believe Clevite would take the time to re-engineer a design that was already working. Does the catalog call for the same part number for both the 4G54 and the 4D56?
Edited by STARION_NORTH, 31 May 2017 - 11:06 AM.
#7 boostinmini
boostinmini
  • 805 posts
Posted 31 May 2017 - 03:27 PM
Yes same part number for both engines the original ones were full bearings on the bottom, this diesels going to be hopped up so I need things to last I feel like maybe I should change the bearings before I get too far end
#8 Guest_STARION_NORTH_*
  • Guests
Posted 31 May 2017 - 06:02 PM
Interesting, maybe Dad can tell us if the different brand bearings he carries are full groove or not?
#9 Dad
Dad
  • 8,101 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 01 June 2017 - 11:31 AM
If its the same part number for the 2.6  then I suspect you got a set packaged wrong.  Should be no groove lower bearings.
Dad
#10 boostinmini
boostinmini
  • 805 posts
Posted 01 June 2017 - 11:46 AM
I googled the part number, it said full groove main bearings, I can find many other sets that are full groove.
I am starting to feel strongly that I would not run them
#11 Guest_STARION_NORTH_*
  • Guests
Posted 01 June 2017 - 03:22 PM
Dad, what brands have you used that are not full groove? Would be nice to know for my own engine build.
#12 Dad
Dad
  • 8,101 posts
    87 White Quest
    87 Shetland
Posted 01 June 2017 - 09:36 PM
Clevite and sealed power bearings for the 2.6 are not full grooved.
#13 G54Bstore
G54Bstore
    SQC Commander
  • 5,090 posts
Posted 02 June 2017 - 08:50 AM
2 best brands in my opinion right there.
All I ever use if I can :D
W18 Rocky White Starion
Daily Driver
