Starts and stalls....
8 replies to this topic
#1 mbruneaux
mbruneaux
  • 1,444 posts
Posted 18 September 2018 - 06:45 AM
Igniter is bad so I installed the 4 pin HEI and it ran great! Actually drove it for a while.  But now it starts and stalls.  The fuel gauge stays solid at 42psi but the A/F gauge goes totally lean and it dies.  I'm hearing all kinds of buzzing I'd never heard before.  Giving it throttle makes no difference.  Will probably start with the Idle reset procedure....
New Injector clips
New GM low impedance injectors
Manual FPR
Generic 4 PIN ignition module - feels kind of warm
Miata TPS properly adjusted to .5 V
Vacuum lines replaced
Canterbury, CT
2001 BMW 740iL - for the wife and children
1998 BMW 528i manual  daily driver
#2 speedyquest
speedyquest
  • 4,151 posts
Posted 18 September 2018 - 09:05 AM
How long does it run for? Also does it start up every time you start it but then die shortly after?
#3 button
button
  • 2,017 posts
  • Interests:1978 Plymouth Arrow
    1974 Dodge Colt
    1990 F45 Tow Rig
    2011 Honda CR-Z
Posted 18 September 2018 - 11:05 AM
My experience with the 4 pin GM HEI module is it needs a good heat sink. I had one fail after only a couple weeks just being mounted to a bracket in the engine bay (not 100% contact to the metal backing). I wound up adding a heatsink to it for added cooling and that one was in the car until it got scrapped. It also requires a good ground on the bolt hole.
Hook up a timing light to the coil wire and watch it for when it stalls.
-Jay
#4 mbruneaux
mbruneaux
  • 1,444 posts
Posted 18 September 2018 - 11:10 AM
I will have to replace it and make sure it's mounted properly.
It runs for about 10 seconds and then just dies.  I think it's the ignition module killing the injectors.
Canterbury, CT
#5 mbruneaux
mbruneaux
  • 1,444 posts
Posted 18 September 2018 - 02:01 PM
This is why I hate/Love Amazon
https://www.amazon.c...C6F3ZG9R224VRCC
Canterbury, CT
#6 button
button
  • 2,017 posts
    1974 Dodge Colt
    1990 F45 Tow Rig
    2011 Honda CR-Z
Posted 18 September 2018 - 02:29 PM
Nice solution.
-Jay
#7 mbruneaux
mbruneaux
  • 1,444 posts
Posted 13 October 2018 - 02:11 PM
Replaced the ignition module and same thing. Put a timing light on it and it gets spark, took the OVCP off and looked into the throttle body.  Starts fine, plenty of fuel, then it peters off into a couple droplets and stalls.  Switched the connectors to eliminate the injector and behaved the same.  Fuel gauge stays at 42psi.  Removed the injectors and made sure they weren't plugged.  If after it starts you stand on the throttle it will stay running but horribly, get off the gas and it dies.
Canterbury, CT
#8 importwarrior
  • 18,295 posts
Posted 13 October 2018 - 06:21 PM
Igniter bad?  Try another one.
There was a recent post here somewhere on this. Canít seem to find it.
Maybe in a different section.
http://www.starquest...howtopic=146193
http://www.starquest...pic=155589&st=0
#9 mbruneaux
mbruneaux
  • 1,444 posts
Posted 13 October 2018 - 08:37 PM
The igniter is unplugged and was running great on the 4 PIN HEI module
Canterbury, CT
