Tbi ms1 v2.2 staged injection problem
13 replies to this topic
#1 boostinmini
boostinmini
  • 933 posts
  • Interests:G54b, 4G63, anything mitsubishi especially pre 2000s, custom fabrication and mountain biking.
Posted 06 March 2019 - 02:45 PM
Hey guys, ms1 v2.2 tbi swap on a mighty Max, 1 out of 10 times when you step into it there is a feeling that it feels like you took your foot off the gas and back on..
Most of the time it does not do it, but it's very abrupt when it does ..
I read a few years ago that it was a soft ware issue but can't find the link to any more, any one experience this?
Edited by boostinmini, 06 March 2019 - 02:46 PM.
#2 speedyquest
speedyquest
  • 4,338 posts
Posted 06 March 2019 - 02:59 PM
There are a ton of different factors to a question like this. Do you have a log of this happening?
#3 boostinmini
boostinmini
  • 933 posts
Posted 06 March 2019 - 03:36 PM
I am trying to get one every time it does it I grab out my phone trying to get a log, but beleieve it or not, will not do it when i am logging.....i will keep trying though
#4 speedyquest
speedyquest
  • 4,338 posts
Posted 06 March 2019 - 03:54 PM
How are you going about making logs? Do you have the ability to connect a laptop to your ecu and use that to create datalogs each time you drive it?
#5 boostinmini
boostinmini
  • 933 posts
Posted 06 March 2019 - 04:13 PM
I use ms Droid with my phone via bluetooth
#6 speedyquest
speedyquest
  • 4,338 posts
Posted 06 March 2019 - 04:24 PM
Is it possible for you to just start logging anytime you drive the vehicle and then when it happens you can hold onto that log and post it here?
#7 boostinmini
boostinmini
  • 933 posts
Posted 06 March 2019 - 04:46 PM
Yes definitely I just don't know how to post the file on this forum I'm pretty much exclusively use my phone pretty rare I'm near a computer but if you wanted I could email it to you when I finally get it
#8 speedyquest
speedyquest
  • 4,338 posts
Posted 06 March 2019 - 04:53 PM
Sure dude, as long as its in a format tunerstudio can actually read I MIGHT be able to notice a problem. Posting it here on the forum means others who probably have plenty of experience could also look at it.
#9 boostinmini
boostinmini
  • 933 posts
Posted 06 March 2019 - 08:52 PM
Hey I've got a log if anyone wants to look at it I can email it for now till I figure out how to post it let me know and I can send you a p.m. whith my email
#10 scott87star
scott87star
  • 5,080 posts
Posted 07 March 2019 - 10:21 AM
PM'ed you my email.
#11 scott87star
scott87star
  • 5,080 posts
Posted 07 March 2019 - 12:44 PM
Something is cutting fuel, it went from pulse width 9 mS to 1.5 mS, then back to 9 mS.  I can't see any rational reason in the tune file, I'd turn off the over run and see if it happens again.  Yes I know over run shouldn't have kicked in but I always turn off over run in any tune file I see, it generally causes more problems than it solves.
#12 boostinmini
boostinmini
  • 933 posts
Posted 07 March 2019 - 02:31 PM
Thank you so much for looking at it I will be at the truck tomorrow and I will make that adjustment and see what happens
Like I said it's kind of odd it doesn't happen all the time only randomly but maybe I'll try and do some more data logging to
#13 boostinmini
boostinmini
  • 933 posts
Posted 08 March 2019 - 04:34 PM
Update, turned off overrun and still does it :(
It only started doing it since i went to staged injection, before i was running both at the same time and did not have any problems..
#14 button
button
  • 2,028 posts
  • Interests:1978 Plymouth Arrow
    1974 Dodge Colt
    1990 F45 Tow Rig
    2011 Honda CR-Z
Posted 08 March 2019 - 08:01 PM
I was thinking overrun at first, but your coolant temp was under overrun setting.
But, your ASE setting is set to fixed map, which shouldn't cause a problem, but it goes to normal map over 122, so I'd try changing that to normal map and see what happens. {edit/I see thats only for 5 seconds}
It doesn't directly correlate, but I'd see what it does.
Also/or, try messing with the second parameter on the staged injection, it's at 100kpa now, try raising it some.
Maybe try turning rev cut to spark only and see what happens.
Also, on my older MS setup, there was a bridge that every time I went under it, my MS acted funny. There was a huge transformer causing crazy electronic noise freaking it out.
So rule out if it happens around the same place on earth vs temperature vs time.
Edited by button, 08 March 2019 - 08:18 PM.
-Jay
