Torque setting for head
14 replies to this topic
#1 Remlor
Remlor
  • 203 posts
Posted 08 July 2005 - 08:14 AM
I am replacing my head with a nonjet, and I need the correct torque setting for the bolts.  I also would like to know if I should torque the bolts on the cam as well.
Yes I am using ARP head studs,  the gasket I will have to check in the morning.
Thanks In Advance
Remlor
Remy
#2 JAinsworth
JAinsworth
  • 16,873 posts
Posted 08 July 2005 - 09:09 AM
The two small head bolts are 11-15 lbs.
The larger bolts are 65-72...cold,  73-79...hot
Cam Bearing caps...14-15
Cam sprocket bolts...37-43
The tightening sequence on the head bolts are, with the 11s being the smaller two in front:
11--8-6-1-3-9
11-10-4-2-5-7
Jimmy
#3 mitsustarion
mitsustarion
  • 640 posts
  • Interests:1dsm2fast4u
Posted 09 July 2005 - 03:51 AM
Nice JAinsworth!! Just a question! What head gasket are you running? And what bolts? (new stock or ARP)? Some head gaskets are a little different in tourque specs. If you have a MLS gasket it's a little more and the ARP's are a little diff. too! Just asking?
#4 JAinsworth
JAinsworth
  • 16,873 posts
Posted 09 July 2005 - 06:27 AM
QUOTE (mitsustarion)
Those are factory specs for a stock engine.  The ARPs are higher and even with them it's different using 30W oil or moly lube.
Jimmy
#5 mitsustarion
mitsustarion
  • 640 posts
Posted 09 July 2005 - 11:55 AM
Ya you said it perfect! I was just wondering if he had the ARP's or a different gasket? I wouldent ever question your reply's JAinsworth,Remlor just dident mention about his gasket or bolts! later
#6 Elkidmino
Elkidmino
    Polack Mechanic
  • 5,622 posts
  • Interests:Burning Rubber
Posted 09 July 2005 - 05:00 PM
I think since JAinsworth did such a good job with that post, this should be moved to the FAQ section... 8)
Magna MPI, SDS-3E, 65lb inj, MSD 6AL, Schnieder HD Springs, S16G, ProfecB-Spec 2 EBC
UAS Strut Bags, KYB Struts, BigRed 2-way Valves, 1/2" air lines, PS2 solenoid controller
#7 Caliber308
Caliber308
    Addicted Starquester
  • 11,923 posts
  • Interests:Precision rifle shooting, Starquests, Sexy women.
Posted 09 July 2005 - 08:09 PM
90 FT LBS with Ajusa MLS and ARP Head Studs. Which I highly recommend. BUT!!!! They have to be tightened in a sequence!!!!!!!!!!!!! Like Jimmy said :wink:  :wink:
87 ESI-R: J.E.s 8 to 1 .040 over, Tims roller cam, Roller rockers,Marnal Head(ported and polished) Scheider HD valvesprings, SS Valves,Zero bal,TDO5H 17 C, K.V., OVC HP, Turbo X/S RFL, Aeromotive FPR, 950/1150 injectors, Walbro , MAF-T, AEM UEGO, Summit dig. CD Ignition. box , Mallory 67k coil,D2s.
#8 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 09 July 2005 - 10:55 PM
NEVER  NEVER  NEVER USE A  1/2 DRIVE  TOURQE WRENCH TO TOURQE BOLTS UNDER  25 FT LBS ,,AND EVEN AT 25 FT LBS I'D BE LEARY
most 1/2 drive  tourqe wrenches  will not read  acurately  at those low  numbers ,,use a 3/8 or an inch lb  t/wrench
#9 Caliber308
Caliber308
  • 11,923 posts
Posted 10 July 2005 - 11:04 AM
QUOTE (Shelby)
OR use a Snap-on 3/8 inch Digital readout Torque wrench. It beeps when torque is met  wink.gif   Only appox. $600.00  ohmy.gif
#10 mstieg
mstieg
  • 6,172 posts
Posted 02 April 2008 - 03:39 PM
Forgive me for not remembering, but what difference on torque specs does the 10W30 oil make vs. the moly lube?
Raise or lower the specs a bit for each?
In Progress: breakin & tune
#11 JAinsworth
JAinsworth
  • 16,873 posts
Posted 02 April 2008 - 04:36 PM
It is more if you use motor oil.
http://arp-fasteners.com/catalog/catalog.html   Page 24.
Jimmy
#12 Caliber308
Caliber308
  • 11,923 posts
Posted 02 April 2008 - 08:15 PM
QUOTE (mstieg @ Apr 2 2008, 08:39 PM) <{POST_SNAPBACK}>
I always use white assembly lube. Heres the specs: Tighten in sequence according to the FSM in a two step process. The sequence is in the FSM page 9-23. ARP Head studs are tighten to 90 foot pounds. So tighten them to 70 in the sequence according to the FSM. Then go back and tighten them to 90 foot pounds still using the same sequence in the FSM.
CALIBER 308
#13 Dad
Dad
  • 8,133 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 03 April 2008 - 07:24 AM
This is a copy of the sheet that ARP included in the 2074202 head stud box..... ( April 2008)
80 lbs with ARP MOLY ASSEMBLY LUBE.   or 120 lbs with 30 wt oil.
As per the instructions-  DO NOT USE ANY OTHER MOLY LUBE or head gasket failure can result.
Dad
#14 Dad
Dad
  • 8,133 posts
    87 White Quest
    87 Shetland
Posted 07 April 2008 - 10:37 PM
QUOTE (Caliber308 @ Apr 2 2008, 09:15 PM) <{POST_SNAPBACK}>
CALIBER 308
I can't find any documents to back up the 90 lb torque with white assembly lube.
Can you back that up with anything  more than just an opinion?
Dad
#15 marso
marso
  • 2,481 posts
Posted 08 April 2008 - 08:07 PM
QUOTE (Dad @ Apr 8 2008, 03:37 AM) <{POST_SNAPBACK}>
Dad
Get em Dad. GGrRRR
Posted ImagePosted Image Chasing ROUS in the Fire Swamp.
