Rear end parts direct from Japan?
26 replies to this topic
#21 NotaDeLorean
NotaDeLorean
  • 75 posts
Posted 17 February 2019 - 09:48 AM
The parts I just pulled are from an 86. If it will be of any use I can send it and be next in line if this works out.
#22 croquest87
  • 1,394 posts
View Postpcristquester, on 17 February 2019 - 09:21 AM, said:
I have a spare on the shelf I was told was good I could send. I donít know if I can confirm what year itís from though.
This one is from 86 wide body  if you feel like comparing measurements.
86 wb shaft basic dimensions https://imgur.com/a/HzZ7AmT
#23 NotaDeLorean
NotaDeLorean
  • 75 posts
Posted 17 February 2019 - 09:56 AM
Wont have time to check it today but I'll try to check get some measurements this week. Would the 87 tt be of any use or would you still prefer I get you some rough measurements to compare?
#24 pcristquester
pcristquester
  • 2,407 posts
Posted 17 February 2019 - 09:59 AM
That’s a lot of info. I’ll give it a shot
#25 croquest87
  • 1,394 posts
Posted 17 February 2019 - 10:01 AM
I would appreciate that. There is a print attached above. When you measure state 100% known year and we will go from there.I can't find any part numbers stamped anywhere.Lengths are what probably matters the most. In particular one from bearing journal to the face of shaft.0ne that's around 13.600 ish.lol
Thank you
Edited by croquest87, 17 February 2019 - 10:05 AM.
#26 NotaDeLorean
NotaDeLorean
  • 75 posts
Posted 17 February 2019 - 10:05 AM
Will do. I'll double check my 86 to your measurements and then measure the 87 when I pull it.
#27 croquest87
  • 1,394 posts
Posted 19 February 2019 - 04:30 PM
Here is another thing we can do to make things work better. Things need grease! Notice that inside hole is pointing at an angle to just the right spot.
Torque tube grease fitting mod https://imgur.com/a/zB2Pdtq
Edited by croquest87, 19 February 2019 - 08:19 PM.
