*SOLD* 1988 Conquest TSi - NY
dmyers151
Hello Everyone,
The time has come for me to sell my car and move on.
I'm selling because I recently got married and bought a house with no garage. For the last 5 years I've been storing the car in a rental building that I split with some friends. However, with the mortgage payment, it's difficult for me to afford rent on the building as well, and I refuse to store the car outside. We're also going to be starting a family eventually, so I need a car that can accommodate a kid.
Basic Info:
1988 Conquest TSi
About 80k original miles
Stock, original engine with balance shafts and jet valves removed
5 speed trans
Black leather interior
Sunroof
Modifications:
Full 3" exhaust with resonator only
MK1 Intercooler hard pipes and BOV
SS braided turbo oil feed line
SS braided turbo coolant feed line
All high quality silicone hose couplers with t-bolt clamps
All vacuum lines replaced with quality silicone
Delphi stock sized fuel injectors (65lb & 95lb)
Hallman manual boost controller, stock 12A turbo at ~17psi
3" GM MAF and MAF translator, street tuned
Custom aluminum radiator based on a smallblock v8 race radiator
D2 coilovers
ST sway bars front & rear
S&M front strut bar
TEP rear strut bar with battery tray
SS braided brake lines front & rear
Dimpled & slotted brake rotors front and rear
SS braided clutch slave line
Optima red top battery mounted in hatch
SHP 8" front wheels, standard 8" rear wheels powder coated gloss black, with 245/45/16 tires all around
Custom made polished aluminum wheel center caps
Sparco 4pt harnesses
Early model manual seatbelt center console with coin tray and accordion shift boot
Delrin shift knob, very comfortable and simple looking
AEM wideband AF guage
AutoMeter Phantom; Boost/Vac, Oil pressure and Water Temp gauges
BTSG short shifter. Shortest & tightest shifts of any SQ short shifter I've felt.
Powder coated valve cover, oil pan, and turbo heat shields
Things I Removed:
Full AC removal, installed non-AC duct under dash
Rear seats (will come with car)
ABS system
Cruise control
Automatic seat belts
Charcoal canister
EGR
Had no stereo when I bought it, but all the wiring is intact
I tried not to cut any wires or plugs when I removed everything, so any future owner would be able to replace it all without too much trouble in that aspect.
Things it needs or coud use:
- Could use an alignment, several suspension changes have been made since the last professional alignment.
- Possibly new front tires. It passed NYS inspection a few weeks ago but they probably only have another year or so left.
- Intermittent wipers don't work, just needs the wiper motor pulled out and cleaned/re-greased.
- Driver's seat left side bolster has a hole
- Has typical frame rail rot, but not terrible. I have two reproduction frame rails that come with the car.
- Has an exhaust rattle when you hit bumps, nothing major. Never bothered me enough to fix.
- Random interior rattles that could probably be easily fixed.
- Has a very small oil leak from the rear main seal. Its not enough to register on the dipstick so I never bothered fixing. It just leaves a small spot on the floor if parked for a few weeks
- Trans output shaft seal needs replacing. I've got the seal, just no time to install it. The trans shifts fine as is. Will grind on fast shifts at high RPM, but it's my understanding that most SQ's do, and I never really drive that way anyways.
Otherwise it needs nothing. I've been driving it about 60 miles a day to and from work with zero issues. I replaced the clutch slave cylinder about 3 weeks ago, the OEM one finally gave out. I change the oil far more often than it needs to be, probably 3 times a season with a total of about 6k miles. I've always used Mobil1 10w30 and BOSCH filters. I've got a drawer full of OEM fuel filters, seals, gaskets, and random stuff that would come with the car; spare alternator, spare power steering pump, stock sway bars, etc...
Post up or PM me if you're interested or have any questions. It's tough trying to describe a car to sell when you never thought you'd be selling it, so I'm sure I missed something.
Asking $5500, could be interested in trades for something with 4 doors, or easier to sell to the masses, lol
Thanks
Edited by dmyers151
Pictures:
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4161_zps5508d743.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4163_zps8e96ddfd.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4149_zpscbbae9ad.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4151_zps35263e37.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4154_zps4b2bacd2.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4155_zps13d67f11.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4158_zps7e794768.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4160_zpsd8bcfd67.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4170_zps6a04bb83.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4172_zps3e77bd4e.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4182_zpsffaf1e0a.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4175_zpsb15be850.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4178_zps2806b7c7.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4184_zpsd82272f2.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4186_zpsb283f873.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4180_zpse551d1e5.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4174_zpsf35da156.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4188_zpsa3671517.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4190_zpsd71195b2.jpg
http://i471.photobucket.com/albums/rr71/dmyers151/1988%20Conquest%20TSi/IMG_4192_zpsc4e8df35.jpg
Thanks for the love guys, easily one of the toughest decisions I've had to make in a long time.
Hey Tae, yeah man it's time. I've had some interest from a few reputable members, guys I know would keep her beautiful for a long time. So I'm optimistic she'll go to a good home.
I know I'll miss it, but I just can't justify keeping it any longer. It costs me $200+ a month to have a place to store it and work on it, which is 40 minutes from home. The house I just bought in January has no garage, and I'm in no position to build one any time soon.
It'll sell, and I'll be sad to see it go, but there are plenty of other things I have to do to keep me occupied.
If I do end up building a garage, or we upgrade to a house with one, you can be sure another car will be on my list.
For now though, it's just irresponsible of me to keep it.
Sorry to hear Dale :( But I understand
For anyone interested I have seen this car in person a dozen times and it is beautiful!
Dale has been downrightjz about keeping it clean and in good running order. You won't be disappointed.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
