88maroon Posted July 14, 2010 Report Share Posted July 14, 2010 hello, my clutch completely drops to the ground at random times and i have to literally pull it back up. it was leaking from the slave cylinder and i replaced that and bled the clutch. but it started doing it again. any ideas? please and thank you Link to comment Share on other sites More sharing options...
h3r3tic Posted July 14, 2010 Report Share Posted July 14, 2010 Did you gravity bleed it? Or pump bleed it. They say gravity bleeding is the only way to get all the air out. Just make sure the lid is off the reservoir. Link to comment Share on other sites More sharing options...
Tman Posted July 14, 2010 Report Share Posted July 14, 2010 sounds like you have air in it or are sucking air in it if you have access too a power bleeder they work wonders too show u leaks if you have one Link to comment Share on other sites More sharing options...
Earl Posted September 14, 2010 Report Share Posted September 14, 2010 check the master cylinder for your clutch=) clean it out once because after many years they build up crud inside and it makes them work horribly=/ You may also need a new master clutch cylinder if cleaning it doesn't work. Link to comment Share on other sites More sharing options...
