gottraction Posted October 13, 2011 Report Share Posted October 13, 2011 Ok i looked in the FAQ and search on the site. i do see a few threads about this. it looks like they all need to be updated. pics arent showing up anymore or the thread is not showing all what im looking for. I read on one post that the vaccum advance is suppose to go to the #1 port. i have no idea where that is at on this car. could someone provide me with a new breakdown with all of the vaccum lines showed with a picture marked showing where they all are suppose to go? My idle is crappy on morning startups and ive replaced the 02 sensor and one coolant temp sensor. Just want to try to narrow it down cause i think the last owner might have ran or blocked off somethings that shouldnt have been blocked! Thanks Link to comment Share on other sites More sharing options...
Spooled_Starion Posted October 13, 2011 Report Share Posted October 13, 2011 I believe that the vacuum advance runs off the number 1 port on the throttle body closest to the firewall. Link to comment Share on other sites More sharing options...
Spooled_Starion Posted October 13, 2011 Report Share Posted October 13, 2011 Also, my 88 starion has the vacuum line diagram printed on the bottom side of my hood. Check yours and see if it's printed on it. Link to comment Share on other sites More sharing options...
KT Posted October 14, 2011 Report Share Posted October 14, 2011 http://starquest.i-x.net/viewtopic.php?t=1219 /thread Link to comment Share on other sites More sharing options...
Em Dot Posted October 14, 2011 Report Share Posted October 14, 2011 ^^ that. i also used the FAQ. just finished this today too. http://i101.photobucket.com/albums/m76/Em_Dot/vacccccc.pnghttp://i101.photobucket.com/albums/m76/Em_Dot/vaccc.png Link to comment Share on other sites More sharing options...
87TSiStock Posted October 16, 2014 Report Share Posted October 16, 2014 where exactly is the purge valve i cant seem to find it unless the other owner already got rid of it Link to comment Share on other sites More sharing options...
DSMracespeed Posted October 16, 2014 Report Share Posted October 16, 2014 Purge valve is under the air can on the charcoal canister Jerry L. Link to comment Share on other sites More sharing options...
importwarrior Posted October 16, 2014 Report Share Posted October 16, 2014 INFAQEngine Exhaust/Intake TurboVacuum Line RemovalPage 3last post This is what i did for my Vac Line Delete my car didnt have AC and it was all removed.Also my car didnt have a charcoal canister underthe air can on passenger side. it was vented in theback near the gas tank. Also there is no BOV so this is absolutly the basic Vac line setup. I was hoping to ADD this to the topic in the Tech section.http://www.starquest...showtopic=28042 The Blue Hose goes to my Boost Gauge on dash. The Center is just blocked off. the Black Hose goes to the Distributor Vac Advance. Below the 3 in a row is the vac line that goes to the Foot FaceActuator for your heater controls. also note the last pic it is #4 if you have a BOV, T off of the Blue vac line shown in the 1st Pic. Thats It. http://i139.photobucket.com/albums/q299/I-W/Quest_Parts_and_Info/IMG_1436.jpg http://i139.photobucket.com/albums/q299/I-W/Quest_Parts_and_Info/IMG_1437.jpg http://i139.photobucket.com/albums/q299/I-W/Quest_Parts_and_Info/IMG_1438.jpg http://i139.photobucket.com/albums/q299/I-W/Quest_Parts_and_Info/Mani-Vac-Ports.gif Link to comment Share on other sites More sharing options...
87TSiStock Posted October 16, 2014 Report Share Posted October 16, 2014 im pretty sure mines been deleted then i dont think i have the charcoal canister either Link to comment Share on other sites More sharing options...
mbruneaux Posted October 19, 2014 Report Share Posted October 19, 2014 I have a hard pipe kit and a manual boost controller to install. With the OVC input gone which of the TB ports do I use #2? Link to comment Share on other sites More sharing options...
mikec Posted October 27, 2014 Report Share Posted October 27, 2014 If your MBC needs boost pressure only (not manifold vacuum/boost) then tap into the port right at the throttle body inlet. That port is not shown in importwarrior's pic. That port is pretty much the same as the factory OVCP port. In the factory service manual diagrams this is the port coming out of the top and pointing towards the right of the throttle body, it connects to the "L" vacuum hose. If your MBC has blowoff/bypass valve functionality, then you need manifold vacuum/boost and you'd use the #4 port on imporwarrior's pics. mike c. Link to comment Share on other sites More sharing options...
mbruneaux Posted October 27, 2014 Report Share Posted October 27, 2014 If your MBC needs boost pressure only (not manifold vacuum/boost) then tap into the port right at the throttle body inlet. That port is not shown in importwarrior's pic. That port is pretty much the same as the factory OVCP port. In the factory service manual diagrams this is the port coming out of the top and pointing towards the right of the throttle body, it connects to the "L" vacuum hose. If your MBC has blowoff/bypass valve functionality, then you need manifold vacuum/boost and you'd use the #4 port on imporwarrior's pics. mike c. Thank you very much Link to comment Share on other sites More sharing options...
