88TSI_Rob Posted November 13, 2005 Report Share Posted November 13, 2005 Un-do 2 outer screws holding the trim and 3 inner screws to remove the turn/fog light housings. Unplug all the lights and you should end up with something like this:http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1OTZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1ODZzNDEzZGZkMzF5NTQx.jpg Notice the 4 metal tabs around the fog light lense? Pop them off using a flat head screwdriver. Also, pull those rubber drain hoses off. At this point you need to heat up the housings to loosen up the silicon sealer. I first ran them under hot water. To clean them off and to warm them up from being outside in the 50 deg. weather. I then set the oven to 180 deg. and let them sit for about 10-15 min. This was enough for me to get the turn signal lenses out, but I needed to keep bumping up the temp to 210 deg. before I could pop the fog lenses out. http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1NzZzNDEzZGZkMzF5NTQx.jpg At this point you could pop in the new lenses, but I wanted mine tinted. I ended up using a spray tint designed for Lexan R/C car bodies. It's Pactra "Racing Finish" RC294 Window Tint. It comes in a 3oz can which is plenty. A couple coats and I ended up with this:http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1NjZzNDEzZGZkMzF5NTQx.jpg A new bead of silicon sealant is applied to the housings and the lenses are installed. http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1NDZzNDEzZGZkMzF5NTQx.jpg Obviously, you just re-install all the lights and scew everything back together the way it came apart. And I ended up with this as the result:http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MzZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MjZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MTZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MDZzNDEzZGZkMzF5NTQx.jpg I considered cutting that reflector out of the fog light housing but decided not to. Now I sort of wish I had cut them out. Other than that I'm really happy with the results. I may post some night pics if anyone is interested. I still have the corner markers to do, but they'll have to wait for another day. Link to comment Share on other sites More sharing options...
Dcrasta Posted November 14, 2005 Report Share Posted November 14, 2005 Very nice and low key. What watt bulb are you running in the fogs? Link to comment Share on other sites More sharing options...
silversmasher86 Posted November 14, 2005 Report Share Posted November 14, 2005 let me know how the side markers go. i got a set too and wana know how hard it realy is. Link to comment Share on other sites More sharing options...
BrokenquestTSI Posted November 17, 2005 Report Share Posted November 17, 2005 Sweeeeeeet!!! Thats car's frookin awesome!! Looks sooo nice. I'm so jealous! Link to comment Share on other sites More sharing options...
bad2theBone Posted December 14, 2005 Report Share Posted December 14, 2005 man that car looks awesome and specially with those lights, man we would like to see some night pics. Link to comment Share on other sites More sharing options...
spoolinturbo Posted December 15, 2005 Report Share Posted December 15, 2005 interesting. i like it. it did not bubble up or anything? I see in your spray pix it looks a little rough around the edges...of course its in a can...so it dried out nice or did you just wetsand it?jeff Link to comment Share on other sites More sharing options...
Kreal Posted December 16, 2005 Report Share Posted December 16, 2005 Would you be interested in doing this if I sent you a set of fog lights & paid you to do it? Looks great! If so, email me please: xkreal@aol.com Will pay! Link to comment Share on other sites More sharing options...
Questsi Posted December 16, 2005 Report Share Posted December 16, 2005 Un-do 2 outer screws holding the trim and 3 inner screws to remove the turn/fog light housings. Unplug all the lights and you should end up with something like this:http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1OTZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1ODZzNDEzZGZkMzF5NTQx.jpg Notice the 4 metal tabs around the fog light lense? Pop them off using a flat head screwdriver. Also, pull those rubber drain hoses off. At this point you need to heat up the housings to loosen up the silicon sealer. I first ran them under hot water. To clean them off and to warm them up from being outside in the 50 deg. weather. I then set the oven to 180 deg. and let them sit for about 10-15 min. This was enough for me to get the turn signal lenses out, but I needed to keep bumping up the temp to 210 deg. before I could pop the fog lenses out. http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1NzZzNDEzZGZkMzF5NTQx.jpg At this point you could pop in the new lenses, but I wanted mine tinted. I ended up using a spray tint designed for Lexan R/C car bodies. It's Pactra "Racing Finish" RC294 Window Tint. It comes in a 3oz can which is plenty. A couple coats and I ended up with this:http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1NjZzNDEzZGZkMzF5NTQx.jpg A new bead of silicon sealant is applied to the housings and the lenses are installed. http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1NDZzNDEzZGZkMzF5NTQx.jpg Obviously, you just re-install all the lights and scew everything back together the way it came apart. And I ended up with this as the result:http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MzZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MjZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MTZzNDEzZGZkMzF5NTQx.jpghttp://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEyNzM1MDZzNDEzZGZkMzF5NTQx.jpg I considered cutting that reflector out of the fog light housing but decided not to. Now I sort of wish I had cut them out. Other than that I'm really happy with the results. I may post some night pics if anyone is interested. I still have the corner markers to do, but they'll have to wait for another day. That looks real slick. I like that look better than the foglight covers that I have. What's that green stuff? Does it come with the kit? 8) Link to comment Share on other sites More sharing options...
emagdnim Posted March 11, 2006 Report Share Posted March 11, 2006 You also get better "glass shine" results when you tape off the outside and spray tint the inside of the glass. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted October 17, 2013 Report Share Posted October 17, 2013 I want the pictures back Link to comment Share on other sites More sharing options...
randy Posted October 20, 2013 Report Share Posted October 20, 2013 I wanna see also Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted November 8, 2013 Report Share Posted November 8, 2013 http://i154.photobucket.com/albums/s263/aiche_photos/Yella%20Quest/3kfogz4.jpgwith 3k HIDzhttp://i154.photobucket.com/albums/s263/aiche_photos/Yella%20Quest/3kfogz2.jpg Link to comment Share on other sites More sharing options...
Skrilla Posted November 8, 2013 Report Share Posted November 8, 2013 Those look like the same ones I have for sale if anyone's interested. Link to comment Share on other sites More sharing options...
