anyone ever make there own gasket or oring set?
oring gasket set for ECI T.B
10 replies to this topic
#1 chris brasher
chris brasher
  • 59 posts
  • Interests:starquest
Posted 09 April 2020 - 06:02 PM
ANYONE ever make there own black rubber ORING's and make there own Gasket's when it came to replacing the ECI throttle body orings and gaskets for there 81,82,and 83 starion 2.6 liter turbo engine with the stock OEM  ECI throttle body?    you can get the kit for a TBI all day long at alot of places on the web.... but there is no kit for gaskets or orings for a ECI throttle body so far............. and i have folks across seas looking for me who also have the same issues............................ i was just curious if anyone attempted this..... i know i have other options changing the fuel system to a TBI ETC......... but i am trying to stick with OEM    if possible................................ i guess this is a question for the veterans who have ever owned a ECI    and it poured gas on them from the top and side............ please write back............ i'll take all the tips and advice i can get................... thanks to everyone who cares to chat back thanks again.... CHRIS from alabama....................
#2 croquest87
  • 1,775 posts
Posted 09 April 2020 - 08:27 PM
Hi Chris . You can make your own stuff and also match seals/orings. Just make sure to use fuel resistant materials. Never did one of these but l do it on motorcycle carbs or just about anything that needs it. It helps to have sharp blades for cutting and hole punch set.
Also for seals there are kits that come with variety of sizes that you can pick OD size  cut it to your desired length and comes w glue to join the ends together (l wouldn't use this to seal any fuel lines)
Orings and seals on this car are metric.
Edited by croquest87, 09 April 2020 - 08:38 PM.
#3 aknorthstar
aknorthstar
    FarNorth Member
  • 1,464 posts
Posted 09 April 2020 - 10:13 PM
https://www.ebay.com...BMAAOSwQz1bJWMj
#4 BuGG
BuGG
  • 1,986 posts
Posted 09 April 2020 - 11:43 PM
The largest seal he needs is 90mm ID x 2mm thick and that is usually pretty hard to come by in kits.  You best bet is to contact a company like ACE Seal or similar and tell them the sizes you need.  You need around 11-13 orings to rebuild the TB.
#5 obsolete
obsolete
  • 475 posts
Posted 10 April 2020 - 12:56 AM
I don't know anything about the '83 ECI unit specifically, but if you are willing and able to measure all the sizes of o-ring you need, I've had great luck ordering from here for other projects: https://www.theoringstore.com/
#6 chris brasher
chris brasher
  • 59 posts
Posted 10 April 2020 - 07:35 AM
i am getting wonderful information you guys are great the more information and places to find materials the better for others to read that have issues like i have....... thank you all for helping alot more then just me................ i know there are others in the same boat im in now,and may have even figured out the best way to tackle such a headache.................. thanks again.
#7 stesir
stesir
  • 1,115 posts
Posted 11 April 2020 - 05:59 AM
I need to get rid of these and letting them go..check out my other listings for more Starion and Conquest TSi parts cheap!
https://www.ebay.com...984.m1555.l2649
#8 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,126 posts
Posted 16 April 2020 - 09:00 PM
You can use the later model year injector seal kits for the bottom on the '83 injectors. I've used orings for the top area. That area isn't as much for sealing fuel as it is for getting the proper height spacing when the hat gets put together. The injector seals are orings inside, and the same ones for later model years work for them too. Still available at Rock Auto.
I'm presently modifying an '83 top hat to fit later year injectors. Mostly because I have several sets of good '84, '85, '86 etc... injectors. so it will be a zero to low dollar fix when I'm done.
'84 Dodge Conquest Parts car
#9 chris brasher
chris brasher
  • 59 posts
Posted 19 April 2020 - 10:54 AM
wow would love to see pictures
#10 Preludedude
Preludedude
  • 3,455 posts
Posted 23 April 2020 - 09:38 AM
https://www.ebay.com...Box!29307!US!-1
#11 chris brasher
chris brasher
  • 59 posts
Posted 23 April 2020 - 01:33 PM
500.00 dollars ouch.....
