83stariontravis Posted November 19, 2014 Report Share Posted November 19, 2014 (edited) Gauging interest on flywheel machining would shoot for 10 flywheels but 20 would be nice. I have a couple sitting here but would need all the cores here aside from my two spares before I run them. One of my spares I will run for an example picture. For my 83 I re-drilled my stock flywheel with the 225mm pattern to accept the 240mm pressure plate and am very happy with how the clutch feels now. I also took the mass off of the back down some lowering the weight of the flywheel from about 35 to 28ish lbs. I am sure I can take off more material than that and will give an estimate after I run another for pictures. Even though it wasn't much weight I did notice that the engine revs a little quicker and more free than before. I did not re-balance and have talked to a few machine shops about lightening flywheels and they seem to agree that if the same amount of material is taken off all the way around that it is not an issue. This would be the case how I did mine and how these would be done as they are not an extreme reduction in weight and is for street driven cars as that is what most SQ owners seem to use their cars for. Another thing to point out is that weight of the flywheel alone is not what affects how the engine responds. Inertia is what maters so removing the big mass from the back of the flywheel even though it is only 6-7lbs makes a bigger difference to the flywheels inertia. Will post a estimation price soon but for sure will be sub 250 probably quite a bit less for what most people will want. Just to be clear all work will be done by a CNC mill not drilling by hand or anything lol. Edited November 19, 2014 by 83stariontravis Quote Link to comment Share on other sites More sharing options...
BC_99 Posted December 8, 2014 Report Share Posted December 8, 2014 If you are going to the trouble of having a program written to lose weight, might I recommend something like this: http://i601.photobucket.com/albums/tt93/BC_99/parts%20car%20and%20parts/20140812_213306_zpsn8vl0iti.jpg I am down to around 19-20 lbs. BC_99 Quote Link to comment Share on other sites More sharing options...
Dad Posted December 8, 2014 Report Share Posted December 8, 2014 Be nice if you can toss in the crankshaft dowel hole since all the cranks have the holes. Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted December 8, 2014 Report Share Posted December 8, 2014 Its a good idea. You are competing with some other options out there. I say make a few and ebay them. Likely to sell. Quote Link to comment Share on other sites More sharing options...
psu_Crash Posted December 8, 2014 Report Share Posted December 8, 2014 Its a good idea. You are competing with some other options out there. I say make a few and ebay them. Likely to sell. Absolutely Quote Link to comment Share on other sites More sharing options...
83stariontravis Posted December 12, 2014 Author Report Share Posted December 12, 2014 All easily doable. After I figure out what end-mill I wanna use I will program that in but a rebalance would be required for sure am I wrong? Quote Link to comment Share on other sites More sharing options...
importwarrior Posted December 12, 2014 Report Share Posted December 12, 2014 yes a balance check should be done for sure. Quote Link to comment Share on other sites More sharing options...
