ECU diagram/drawing
5 replies to this topic
#1 seb
seb
  • 55 posts
Posted 17 July 2019 - 10:27 AM
Has anybody got a drawing of all internal components of the ecu? Or know where i might be able to find one?
Basically having ecu troubles, one of my ecu's is not giving out an ignition pulse, (checked all other componentd etc)
I can get my ecu repaired but need to know what each components function inside is
Thanks for any help
#2 pcristquester
pcristquester
  • 2,476 posts
Posted 17 July 2019 - 10:45 AM
Good used ones are cheap on here if you post on wanted items
#3 scott87star
scott87star
  • 5,014 posts
Posted 17 July 2019 - 08:25 PM
Ah, the ECU does not put out an ignition pulse, it receives one from the coil.  The distributor/knock box/coil control ignition.
#4 seb
seb
  • 55 posts
Posted 18 July 2019 - 02:33 AM
I'm in the UK and my car is a 2.0, i have sourced a replacement ecu from a guy on the UK owners club, just waiting to get it posted across. However i would like to repair my ecu and not just bin it, cheers
#5 seb
seb
  • 55 posts
Posted 18 July 2019 - 02:43 AM
Basically my car broke down, would not start as the injectors stopped firing, i put an LED in the diagnostics port and it gave me code 2- ignition pulse. The fuel pump was delivering fuel, there was a spark going to the plugs, the tach needle was bouncing, car started momentarily on easy start. Tried a different knockbox- no different. Switched to another ecu (one that will run the car but is hard to start with as it appears to not adjust the isc servo correctly for starting) and managed to start the car. So that tells me there is something within the ecu not gettting the igntion pulse through?
My other ecu which is creating a hard start but will run, gives codes 3 & 4, would like to know what all the components do inside the ecu if possible
#6 markhansenconquest
markhansenconquest
  • 3,491 posts
Posted 18 July 2019 - 05:30 PM
Whats the part number of ECU.......??(on side of ECU ) I have 4-5 that I dont know what year they go TOO.........maybe 1 is the one U need........??    the manuals don t even have the workings of ECU.....I took apart a  87 that went bad and U could see the burned dieodes.......2  of them..........does your passenger side leak water on ECU?? If drains get plugged it over flows to wire LOOM and right down to ECU connector plug and shorts them out.............put water on cowls and see if water shows up at ECU location ,,before U put a new one IN.....................IMO
Edited by markhansenconquest, 18 July 2019 - 06:09 PM.
