starion1991 Posted March 3, 2008 Report Share Posted March 3, 2008 Soooo... I got everything hooked up on the starion, put new oil and filter, primed turbo...Then i fired it up after a good priming So...it fired quickly...but right as it fired up it started smoking...no delay...right when it fired :shock: ... Thats scaring me alot!!...should i worry about it?? My dads frend thinks its from all the un-burned oil that the blown turbo left in the manafold...im not shure though... It is also kinda running rough...i think thats becaus the vac lines arent hooked up properly...previous owner deleted some stuff and it has lines unplugged.. I also drove it around the warehouses...not fast at all... it seemed ok, i did NOT get it into boost at all... Let me know what you guys think...i hope its from all the oil left in the manafold... Link to comment Share on other sites More sharing options...
FijiPhil Posted March 3, 2008 Report Share Posted March 3, 2008 if its smoke from the engine bay then your probably ok, but if its from the exhaust then id be worried. Also, how much smoke are you talkin about? Link to comment Share on other sites More sharing options...
starion1991 Posted March 3, 2008 Author Report Share Posted March 3, 2008 theres some from the engen bay, and alot came out of the exzaust when i fired it up..it started to die out and barly smoke unless i hit the gas.. Link to comment Share on other sites More sharing options...
starion1991 Posted March 3, 2008 Author Report Share Posted March 3, 2008 any help? :-k Link to comment Share on other sites More sharing options...
speedyquest Posted March 3, 2008 Report Share Posted March 3, 2008 from what i understand, alot of smoke coming from your exhaust is most likely a bad turbo seal.... im a bit new to this but thats what the service manual says... hope this helps you Link to comment Share on other sites More sharing options...
starion1991 Posted March 3, 2008 Author Report Share Posted March 3, 2008 well the turbo is freshly rebult, that was the orignal problem, bad seals! Link to comment Share on other sites More sharing options...
Outlander Posted March 3, 2008 Report Share Posted March 3, 2008 think it could be old oil residue from when the turbo was bad? If everything else looks good take it for a spin and burn some of that old oil out. Link to comment Share on other sites More sharing options...
Technology Posted March 3, 2008 Report Share Posted March 3, 2008 Sounds like something for basic tech. Do you have some goofy roller rocker setup that chewed the valve seals up? are any return hoses to the oil pan or front timing cover not connected or tight? they could spray oil on the exhaust (usually only at high rpm while driving, but hey). Link to comment Share on other sites More sharing options...
boostandmuscle Posted March 3, 2008 Report Share Posted March 3, 2008 new turbos also smoke for a little while.. its all the coating baking off of them... suprised nobody said this yet lol Link to comment Share on other sites More sharing options...
starion1991 Posted March 4, 2008 Author Report Share Posted March 4, 2008 new turbos also smoke for a little while.. its all the coating baking off of them... suprised nobody said this yet lolLeave it to the noob , just messin bro, thanks yea today i fired it up and no smoke at all, just under boost and its alot less than the day before, its all the unburned oil the old turbo left, its burning em off Link to comment Share on other sites More sharing options...
