My 88 Starion
twojayzeestarion
The car didn't come with a motor but I didn't care because I had one setting that I had found on craigslist for 200$ I went to work and had it in two days later. Didn't take any pics but I have one of when it was in the carhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10620809_784007004954728_3959031238177668391_n.jpg
I also had my exhaust done I used mookeeh's 3" exhaust because it came with the car. It didn't fit the way I wanted it to ( didn't fit very well at all to be honest) so I cut it all up ordered a borla xr-1 blow threw muffler and welded it back together the way it should have came...http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10358568_793791437309618_8703892451927619874_n.jpg
This motor ran just fine for about 2 months and then the turbo blew its seals. Being that I lived in Oregon money pretty literally grew in my back yard and I saved up enough to finally do what I had dreamed of for almost 5 years a 2jz swap..
So I went back to work and built a ghetto little garage to build it in as the wet season had also began
Then I started pulling everything apart
http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10734265_808533602502068_5777490859789467443_n.jpg
So finally all my parts arrived and I was ready to start back
The tranny I bought came from a 7m supra so I needed a 1jz bellhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10387202_808533929168702_2217268674348899743_n.jpg
Vettekillers motor mountshttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10422080_808533949168700_5654681443239327067_n.jpg
Clutchhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10425401_808533652502063_3760800139789626481_n.jpg
My 2jz arrived and man was I happyhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10801698_808534005835361_8900410576848161468_n.jpghttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/1385991_808534035835358_7844672013808968080_n.jpg
The next day I promptly started pulling stuff off and installed the motor mounts and managed to get the motor inhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10409436_808534129168682_2123663731807704245_n.jpg
Unfortunately I rushed that to much and didn't realize that in order to run the wiring harness were it need to be and get the tranny in without cutting the rad support the motor had to be unbolted and slid all the way forward I did this the next day also mocked up my ic piping
http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10610938_808534162502012_4399758272329074491_n.jpg
http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/250375_809009825787779_6469084168147556221_n.jpghttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/250375_809009869121108_6724781322737147967_n.jpg
After this there was very little to do. Since the fuel line was left on the jz in scaved it bolted up to starion fuel filter.
The throttle cable had to be ground down to fit the jz cruise control wire holder as the jz throttle cable wire hole was much largerhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/1461467_809009779121117_881905224325140115_n.jpg
I used a Starion fuel pressure line for my brake booster hose because the banjo bolt threaded into were a plug was in the intakehttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/1509009_809009909121104_2357651849890374323_n.jpg
Got everything hooked up and tightened downhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10394008_816216728400422_777409416428433382_n.jpghttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/16391_816216748400420_3300662991398117135_n.jpg
Power steeringhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10801862_816216778400417_6301937000731695205_n.jpg
For Fans I used twin 10" because I wanted my air dam to still look worth a damn even 10" fans was a tight fit. Car runs 175-180°
http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10686878_816216808400414_7397872816280771052_n.jpg
Everything completedhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/10547433_816216838400411_6875099525557664594_n.jpghttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/1455152_816216871733741_3963347437869275144_n.jpg
And yes I built this entire car in a gravel driveway<a href="http://s998.photobucket.com/user/scooterdude92/media/Mobile%20Uploads/969022_816216891733739_1677861644973982850_n.jpg.html" target="_blank"><img src="http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/969022_816216891733739_1677861644973982850_n.jpg" border="0" alt=" photo 969022_816216891733739_1677861644973982850_n.jpg"/></a>http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/553254_816216918400403_6726910910691270359_n.jpg
More updates to come soon!!
-Curt
Clutch
My 2jz arrived and man was I happyhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/1385991_808534035835358_7844672013808968080_n.jpg
I've never seen an actual picture of true love. but this is it....
Get that thing built!
Next I started hoarding rare parts managed to gather up a few sets of 83 taillights and hoods and a couple sets of shp wheels.
9's all around 83 hoodhttp://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/IMG_20150117_171011.jpg
83 tail lights
http://i998.photobucket.com/albums/af108/scooterdude92/Mobile%20Uploads/IMG_20150117_171033.jpg
More to come
Edited by twojayzeestarion
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
