WOOHOO BLOWN HEAD GASKET
37 replies to this topic
#1 Ironside
Ironside
  • 1,908 posts
  • Interests:Hummmm Conquests ,Starions , Dodge diesels welding and life....
Posted 04 March 2017 - 08:46 PM
Yup first one for me.
110
100
50
50
I'll be giving Randy a call.
87 White 5-Speed Starion.Gen 2 maft, 3" lt1 mass,rebuilt motor, ss valves, schnider springs, roller rockers new head from Dad, stage 3 clutch, tdo6 18g
88 White 5-Speed Starion, parts car.
89 Red Automatic Conquest TSI, on the road running. Getting ready for paint. All stock.
#2 TexasQuest
  • 8,861 posts
Posted 04 March 2017 - 08:54 PM
Overheat? Too much boost?
88 Fiji Blue -Tsi
#3 Ironside
Ironside
  • 1,908 posts
Posted 04 March 2017 - 09:08 PM
Didn't over heat. Probably to much boost. I have a very cheap manual boost controller.
I hit 25 psi on accident, pulled over and lowered it. Ran a half a tank before it started smoking.
Edited by Ironside, 04 March 2017 - 09:10 PM.
#4 87redcat
87redcat
    10 years and counting...
  • 3,841 posts
Posted 04 March 2017 - 09:10 PM
Just had Randy put a head together for me. Great work!
#5 G54Bstore
G54Bstore
    SQC Commander
  • 5,157 posts
Posted 05 March 2017 - 09:53 AM
Bummer buddy. One of those things these cars do until done right unfortunately.
GL with it.
W18 Rocky White Starion
Daily Driver
#6 louswheel
louswheel
    King Kong Status
  • 9,296 posts
Posted 05 March 2017 - 08:05 PM
Who gets excited over blown headgasket? Only a StarQuest owner! :lol:
Its been 12 years since I last experienced one.  Have fun putting it back together.
#7 Bradrock
Bradrock
  • 956 posts
Posted 05 March 2017 - 08:44 PM
Life's too short to sweat the small stuff!  Fix you up in five minutes!
:) :) :D
I don't see on the label how much boost it's good for?
Run's with scizzor's
#8 TexasQuest
  • 8,861 posts
Posted 05 March 2017 - 09:59 PM
Sucks man, that's one reason I don't use cheap parts. I had a TurboXS mbc and I was boost spiking bad! I yanked that thing out and got a Hallman mbc. Not a problem since.
88 Fiji Blue -Tsi
#9 importwarrior
  • 18,269 posts
Posted 06 March 2017 - 05:50 AM
yup i use the Hallman as well. hope it is just the gasket not a crack between the valves....
#10 Skullzaflare
Skullzaflare
  • 4,747 posts
  • Interests:Computers, hotrods, ratrods
Posted 06 March 2017 - 09:08 AM
Crack wont lower compression. Id be more worried about ringlands if the boost shot higher than tuned
I ran 24 all day every day on my hx40, actually, ignoring that, i have NEVER blown a gasket on a g54, broken plenty of ringlands though lol
Spark plug elimination kit
#11 Dad
Dad
  • 8,142 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 06 March 2017 - 12:27 PM
Look close at  the top of block for cracks, mainly on exhaust side, head bolts and water holes.
#12 Chad
Chad
    noob
  • 9,182 posts
  • Interests:Starquest Fanatic
Posted 06 March 2017 - 01:46 PM
I had a Crack between all of the cylinder sleeves after a head cracking overheat, didn't show up till I tossed the block in the scrap pile and rust formed on the surface.  Then the Crack was easy to see.  Cracked blocks aren't common, but they do happen.
#13 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,377 posts
Posted 06 March 2017 - 04:03 PM
BOOM BOOST ... same thing :P
          MOPAR POWERED
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,438 posts
Posted 07 March 2017 - 10:29 AM
No, the cracks are pretty common. You just have to be lookin for it.
Cracked between the sleeves?
Listen to Randy. Those spots need looked at. Also, those cracks show up on the headgasket a lot of times.
Edited by Funky Phil, 07 March 2017 - 10:44 AM.
#15 jinx
jinx
  • 1,908 posts
Posted 07 March 2017 - 11:13 AM
g54b must b on crack... :lol: often the last straw for alot of folks that swapped or bailed.
There was a decent dialogue way back, on probable causes
http://www.starquest...howtopic=149982
http://www.starquest...howtopic=149983
Edited by jinx, 07 March 2017 - 11:14 AM.
#16 Ironside
Ironside
  • 1,908 posts
Posted 07 March 2017 - 12:51 PM
Exactly... Just a hobby car.
:) :) :D
That'll fix it. Forgot about that.
I'll put it in gas, oil, and coolant just to be safe....
Be sure to check.
Great, thanks for all the advice. I'll look into all of the above.
Edited by Ironside, 07 March 2017 - 12:54 PM.
#17 Fuze
Fuze
    AKA @Battlemagnet
  • 2,757 posts
  • Interests:Chess Boxing
Posted 08 March 2017 - 12:01 PM
Used to blow them all the time, but since putting ARP studs in along with the good FelPro gasket, it's been all good. Running 20+PSI all the time on my little TD06 Super 16G.
Insta = @battlemagnet
#18 Ironside
Ironside
  • 1,908 posts
Posted 08 March 2017 - 08:00 PM
You think the felpro is better then the metal head gasket? I'm running arp studs.
#19 BC_99
BC_99
    Plays in traffic
  • 5,211 posts
Posted 08 March 2017 - 08:06 PM
Perry!!!!!!!!!!!!!!!!!!!!
I've heard plenty of arguments both ways. felpro vs. ajusa. Both are good gaskets.
First things first. Tear that baby apart and see what you got going on. Do you have coolant in the oil? Steam out the tail pipe? Did you do a leak down test on the 2 low cylinders?
BC
#20 Ironside
Ironside
  • 1,908 posts
Posted 09 March 2017 - 04:11 AM
No coolant in the oil. My son was driving it and seen a lot of white smoke ( coolant I'm guessing) all the plugs were pig rich black.
I do need to do a leak down test before I pull it apart.
