water pump variation question
88-cnqst-tsi
is there a difference between this water pump http://www.napaonlin...2173_0258157938 and this one http://www.napaonlin...1180_0267404090. im only asking because the first one has a cap on top of the blade when the second one doesn't, does it matter or do they work the same. Also there are two holes on side of the case on the dry side that you can see the shaft from, what are they for Edited by 88-cnqst-tsi
Uncapped is 87. Capped is 88. 88 probably flows better, but there is no data on the difference.
86 and below also use the uncapped, but do not have the coolant return port on the pump.
Exterior holes are weep holes... when they weep, your pump seals are bad.
-Robert
-Robert
so should it be ok to use the uncapped one
both pics are of the same water pump , the port above the lower rad hose may be plug'd on one but can't tell from pic ,,87 up and late 86 all use'd the same water pump , that port is the return from turbo ,, if your's has the return line from turbo going to water pump ,,then get the one with that port
open
open
they have the same ports..i know that but in the rest of the post I ask if there's a difference between the capped blades and open blades
I have wondered the same thing. The first picture (new after market) looks to have a cast aluminum impeller. The second (remanufactured) the steel impeller.
The pump i bought new from Mitsu for an 88 had the steel impeller. I would have to double check the parts #'s.
There once was a local guy who said he solved an over heat problem by replacing the water pump. But i know no details on that.
I would think that thermostat will regulate the water flow regardless, unless the impeller is so small that it can't flow enough volume.
the uncap'd blade uses the frt of the block as the reaction plate , the cover'd plate not so much
of the two i'd say the cover'd blade may push more coolant at a lower rpm,,
along these lines back in the ol school days a hi perf water pump actualy pump'd less water then the stock one . same with a/c and non a/c engines ,m a/c pumps push'd a bit more coolant at low rpms
