How To Install MR2 Inserts in your Starion
51 replies to this topic
#1 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 09 November 2009 - 05:54 AM
http://home.comcast....nMR2Inserts.htm
Check it out, I finally finished it.
-Robert
#2 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 09 November 2009 - 06:16 AM
Hmmm... by saving the stock spring perches, you could actually reuse them and use stock springs still.  You will just be about 2" lower and can use cheap GR-2 inserts ($43.95 from summitracing.com).
-Robert
#3 Convette
Convette
    I used to driftjunk
  • 4,987 posts
  • Interests:Going faster
Posted 09 November 2009 - 08:59 AM
good write up
#4 smallblock12
smallblock12
  • 2,869 posts
Posted 09 November 2009 - 09:00 AM
so you used celica strut tops on your non shp struts?
89 Palermo- slammed! (R.I.P.)
95 awd talon
92 mighty max- DD, awaiting slammage....
#5 psu_Crash
psu_Crash
  • 6,893 posts
Posted 09 November 2009 - 12:57 PM
Nice write-up and website, Zoom profile comes up page not found?
That video of your buddy's Aries is hilarious!
'86 Starion, MPI with MS2extra, Ebay To4E 57 Trim (in testing), P&P head, OS SS Valves, Wiseco +.030, ARP head/rod, O-Ringed Block, Schneider 284-H, prepped rods,AEM H2O/Meth Injection, Mighty Max CAS 4 Direct Fire Wasted Spark, BSE, Tial 38mm, JDL exhaust mani, HKS turbo timer and EVC3, AEM UEGO, 3" DP into 2 1/2" Dual Exhaust, 75# Delphi's, Magna modded by Chad, Accufab FPR, Walbro 255, D2 Coilovers, Poly Bushings, Funk-Lock, LED Tails and Dome ... etc^4
My Feedback Link
#6 D_Venable
D_Venable
  • 6,588 posts
Posted 09 November 2009 - 07:47 PM
-Robert
That would probably require skinnier wheels and tires for clearance then, hehe
But Very nice write-up.  for the gland nuts on mine, I used the biggest channel locks I had, then hit the end with a mallet, this provided the force needed to break it loose.
Derek
2011 Silverado
88 TSI parts car
#7 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 09 November 2009 - 10:31 PM
Thanks!!  I got ZooM's profile working again, the internets is case sensitive.
Haha, I wish I was friends with Tim trying to sell his Aries... he's just so cool.
-Robert
#8 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 09 November 2009 - 10:33 PM
Derek
Yeah, I thought about it on the way home that it wouldn't work.  You could always weld the spring perch at stock height and use lowered springs.  Orrrr... just make a spacer haha.
No, not on this install.  When non shp struts are too hard to find, I will probably switch over to celica strut tops and use the toyota gland nut. That is what SFBMX88 did I believe.
-Robert
Edited by Komeuppance, 09 November 2009 - 10:35 PM.
#9 smallblock12
smallblock12
  • 2,869 posts
Posted 18 November 2009 - 10:46 PM
oh sorry fo some reason i thought that was you. but anyway i have shp struts and im wanting to slam my fiji bad. will it be driveable without cambers for a little??
95 awd talon
#10 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 20 November 2009 - 03:07 AM
Haha... it'll be driveable.  But I consider lots of things "driveable"... LOL... I wouldn't do it for long, your turn in is going to suck really bad and the car will want to wander all over the place.  Besides all the tire wear.  If you adjust the toe, it should be more stable.  Back end will be nice and squirely.
How low do you want to go...??
-Robert
#11 sittin-sideways
sittin-sideways
  • 582 posts
  • Interests:drifting,hagging out,and spending time with my son and wife
Posted 23 November 2009 - 07:59 PM
dam that car is slammed, i just did this same convertion and my front sit higher then back and i got new mk1 camber plates, which i think that was costing it look that way.
when you welded that spring patch on the housing did you lower it lower then stock position??
#12 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 23 November 2009 - 11:17 PM
Yes, all sleeve over perches are welded in a lower position, just over 2" lower.  You cut and rewelded your struts??  Or you left the strut housings at stock height and used spacers inside for the MR2 inserts??
I daily drive it like that, and I love it.
-Robert
#13 Laodicea
Laodicea
    Celebrity
  • 1,340 posts
  • Interests:Heaven
Posted 24 November 2009 - 05:54 PM
-Robert
You can also just get an xtra pair of stock fronts or bad ones and cut the tops off and then weld them onto the rears like I did....
Gnothi Seauton 515 rwhp/527 Lbs.@21psi....nuff said.
2JZ-HX40 Na-T swap Conquest.  FAST Classic ECU, dual walbros -8an PTFE, stock NA pistons & Turbo HG, Arps, Custom FFIM for 1200cc injectors ..93 oct. daily driven.
http://i156.photobuc...ct/DSC01364.jpg
#14 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 24 November 2009 - 10:02 PM
Haha... yeah... detailed in my guide.  But, I didn't paint mine purple!!
-Robert
#15 Laodicea
Laodicea
    Celebrity
  • 1,340 posts
  • Interests:Heaven
Posted 24 November 2009 - 11:36 PM
-Robert
I was gonna sandblast them and powdercoat them the HKS purple look ..but I was lazy...I am such a loser.
#16 smallblock12
smallblock12
  • 2,869 posts
Posted 25 November 2009 - 07:31 PM
i wanna be low as i can go and still drive it daily. someone was telling me that this would hurt my handling o to the poaition of the a arms
95 awd talon
#17 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 25 November 2009 - 07:57 PM
I have MK1's roll center adjusters (RCA's)... just today I was thinking about putting some good tires on and doing a skid pad test to see how many g's I could pull.
-Robert
#18 smallblock12
smallblock12
  • 2,869 posts
Posted 26 November 2009 - 05:35 PM
do it!! hey could you take some more pics of you car by chance maybe like a few different angles. i reall wanna see its stance
95 awd talon
#19 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 23 March 2010 - 03:48 AM
Update:  It's still AWESOME.  Probably one of the best mods you can do for your car's handling.  Even if you don't drop it down much you can still get a GREAT ride height and still be safe.  I had to make many other modifications to the car to be able to drive this low on the daily.
-Robert
#20 Garrett_M
Garrett_M
  • 32 posts
  • Interests:TURBOCHARGERS!
Posted 04 May 2010 - 05:44 PM
this should be a sticky :)
