vacuum advance question
5 replies to this topic
#1 seanc77339
seanc77339
  • 28 posts
Posted 23 August 2011 - 09:04 PM
1. What happens if you block off the farthest and the second farthest nipple on the TB of an 1987 flat-body conquest while leaving only the first one close to the firewall still stock and connected??
SC :ph34r:
#2 Indiana
Indiana
    Addicted Starquester
  • 14,730 posts
Posted 24 August 2011 - 01:22 AM
Nothing, most do that anyway.
#3 Caliber308
Caliber308
  • 11,923 posts
  • Interests:Precision rifle shooting, Starquests, Sexy women.
Posted 24 August 2011 - 01:48 PM
First port on the Throttle body towards the front of the car is:
Distributor Advance Control Vacuum. (Nipple D) DO NOT REMOVE OR CAP THIS PORT.
The Second port is:
EGR Valve Control Vacuum. (Nipple E)
The third port is:
Secondary Air Control Vacuum. ( Nipple M)
If you still have the second (Nipple E) and third port (Nipple M) active.Removing the vacuum lines can wreck havoc on you entire system.
Bill
Edited by Caliber308, 24 August 2011 - 02:06 PM.
87 ESI-R: J.E.s 8 to 1 .040 over, Tims roller cam, Roller rockers,Marnal Head(ported and polished) Scheider HD valvesprings, SS Valves,Zero bal,TDO5H 17 C, K.V., OVC HP, Turbo X/S RFL, Aeromotive FPR, 950/1150 injectors, Walbro , MAF-T, AEM UEGO, Summit dig. CD Ignition. box , Mallory 67k coil,D2s.
#4 MikeMeyerhoff
MikeMeyerhoff
    I mod therefore I am
  • 5,599 posts
Posted 24 August 2011 - 07:25 PM
Here is an understandable explanation of the vac system.
http://www.starquest...l=&fromsearch=1
Just disconnecting those lines and leaving everything else might cause some problems with the EGR.  You'll need to also cap both blue line feeds to the EGR
Kevlar Bands for Starquest Automatics - $50  Out of Stock  (I Pay $15 for cores)
Rational,  Irrational,  Beerrational.
#5 seanc77339
seanc77339
  • 28 posts
Posted 24 August 2011 - 07:43 PM
I was wondering how is this gentleman at:
http://www.cardomain...subishi-starion
Is running his vacuum lines. I like how it is so clean in his engine bay.
Any ideas on how he has accomplished this would be appreciated.
Thanks,
SC :ph34r:
#6 seanc77339
seanc77339
  • 28 posts
Posted 24 August 2011 - 10:29 PM
I have removed my secondary air cleaner. What is the purpose of the Purge control valve??
THanks again,
SC :ph34r:
